05 W211 Replaced Steering Wheel Airbag, now horn and buttons not working
E200 CDI 2005 5G-TRONIC, A170 CDI 1999, C180 1995
Same problem
I have bought my car from a used car dealership with the buttons and horns on steering not working. I have checked the spiral link and it is ok. I also get communication error. I have acquired an airbag with the original (after the vin) number and it still has the same problem.
Any luck with your case?
Checked the fuses and relays too. I thought the horn is a sepparate circuit but I see it communicates via CAN, am I correct? There is a module in the steering wheel column in which the spiral is plugged in, is that a phisical one or it also processes data? From the buttons onward everything seems to be ok. I dont quite understand with whom the ecu cannot communicate. The airbag module or something else located in the steering wheel column
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
What about the actual horn connections----they sometimes get ugly!!
What do you mean by this-----" dont quite understand with whom the ecu cannot communicate."
Checked everything, the horns relay doesnt get any signal. Communication error with the buttons controller. I could use a wiring diagram for the steering wheel column. I dont understand the signals route
#32
Airbag module needs coding (using Online Star Diagnosis so it knows what stuff is in your car), and really the SCM which is part of the switch-pack around the steering wheel set needs coding if you change that (but not sure if you are doing that).
I'm pretty sure (but others please correct me!) that the airbag module is locked to the car - although it may just be the coding of what airbags etc is in the car is locked once initially done, and that after an airbag deployment the module must be replaced (i.e can't be reset, apart from just the risk that the electronics that triggered the bag may be fried)
Richard
Like
__________________
Of course i'll take it apart.
Comand Online Ltd: We're listed on MBClub - please click to see our products and discounts available.
Currently Modding: W166 ML63, what shall I do next? TV? Soft close doors? Keyless Go?
My own car Mods: W166 ML63 garage door opener. W164 ML63 RSE,DAB,TV etc.
Previous Mercs: W164 ML500, W163 ML500, W169 A180CDI, R230 SL55, W163 ML430, W208 CLK55, R129 SL500, W208 CLK320, R170 SLK230, 1st Merc = R129 SL320.
#33
Update:
Part a0365457032 is missing from my steering wheel :-) it is a signal converter for prefaceloft as i understood. Thats why the communication error. I am searching a used one around my town. Be back with updates.
Unfortunately mine still does not work as I'm fed up trying, I replaced steering modul still nothing so I asked someone with more knowladge and here is the reply from him;
Richard
Like
__________________
Richard
Like
__________________
#34
Here is the part matches your part number: http://www.ebay.de/itm/Schaltkasten-...-/171103943991
#38
Having the same issue.
DTC 9001, LIN bus communication error in the SCM (steering control module).
The connections all work, transmission shift buttons work, but when I use iCarsoft to see if the SCM seeing buttons being pressed, it doesn't see the the gearshift button action.
Bizarre. happened after I removed the steering wheel.
Clearing the code brings it back instantaneously.
