E-Class (W211) 2003-2009
Risks of being Lowered
Old Feb 1, 2014 | 01:19 AM
Inspiredbenz's Avatar
SOLD W203..CURRENTLY DRIVING W211
Exclamation Risks of being Lowered
Hey guys I recently got my w211 lowered via star, im not feeling the drop I have a 2 finger gap all around would like to go lower.
I know the usual tire wear that comes with being lowered witch I dont mind but are their any other issues I should be worried like (suspension components being stressed if I stay low and dont get an alignment ) .
Old Feb 1, 2014 | 01:28 AM
mercedes4ever's Avatar
2004.7 C180 Kompressor, BMW X5, Chevrolet Camaro LT, Mercedes S, Cesna 152.
Check with your Local State Laws as to the legalities of your "adjusted" Vehicle height. I would suggest they have lowered it to comply, any further lowering may compromise your insurance in the event of a claim / accident. Also if you have a front tire blowout, the cars suspension / sump area may impact the road surface, causing you to loose control & damage your vehicle / others and the road surface.
Old Feb 1, 2014 | 01:08 PM
pinebaron's Avatar
07 E320 Bluetec
It's not a problem if you do everything properly. Though not as much as some folk, at rest my tires sit at least 1/2" inside the well. No doubt I spent a small fortune with the components and installation (see my signature) but could not be happier.
Old Feb 1, 2014 | 01:36 PM
Craftysince86's Avatar
W211
i think it depends if you are trying to just lower it or are you trying to LOWER it...
its all the same for any car, premature wearing on all suspension components i.e. bushings, ball joints, wheel bearings, etc.
i have seen very few lowered E's in all honesty... people put springs or get rid of the their wheel gap on stock tires and all the sudden they are "slammed"
if you don't care about the sunken look then it's easy, just keep an eye on ball joints because the lower you go the more stress you put on them. you def don't want to lose a ball joint while driving. i believe lowering it with star you will use your stock air ride? stock struts are not made to be that compressed when the car is low so they will go, ride quality will obviously change because you will have less air in the bags.
moral of the story there is a right way and wrong way to do it
just speaking from experience from a long line of "lowered" cars, all of them static
Old Feb 1, 2014 | 01:48 PM
W211
fitment was another important thing to me, which is another whole list of things you have to look at
Old Feb 1, 2014 | 02:26 PM
jagata's Avatar
S6 LP640 E500
I love how your wheels sit flush, great job. Btw plastidip those window trim if you want a fresher looking trim.
Old Feb 1, 2014 | 02:30 PM
W211
Lol thanks for the longest time I have wanted to figure out how to clean those up, do you just use the matte black? Or do they even offer plasti dip in a gloss?
Old Feb 1, 2014 | 02:33 PM
Thanks for replys guys
Crafty- I do hear sum squeaky sound from driver ball joint which i replaced less than 500 miles ago...loosing a ball joint while driving scares me ( but how likely is that to happen )
Old Feb 2, 2014 | 12:29 PM
W211
do you have pictures? everyone has different opinions of what low is... if you just replaced them you will be fine. like i said though the lower you go the more you change the geometry of the suspension and how the components were engineered. when you drop a car you start tweaking parts and they're forced function under angles and loads they weren't meant for.
Old Feb 2, 2014 | 04:01 PM
SilverTiger's Avatar
E500 Wagon
How do you lower a E500 with airmatic? What is the best way?
I thinking about 1-1.5" from stock height. This is nothing compare to some the W211's in the post.
thanks
Old Feb 2, 2014 | 04:47 PM
AMGAffalterbach's Avatar
2014 BMW M235i
You can do it via STAR diagnostics for the AirMatic, just find a shop to change it through the computer and set the new ride height. I like the lowered look just a tad above the tire so there's no gap but it isn't slammed. You're in California so you're lucky that you're in a state with a bunch of Mercedes shops that will do it for you, tried almost every shop in Colorado that has a STAR computer and with no luck. The other thing you can do is install lowering links to trick the sensor into thinking the car is higher than it really is, that's probably the best way. But again, no shop here would install them for me. Wish I had found MBClinic sooner.
My dad is from Carmel by the way, what a beautiful town.
Old Feb 2, 2014 | 07:37 PM
LemonSqueezy's Avatar
14 550 sedan
thanks
Washer method + star lowering is how I lowered about 1.5 inches. I would go lower but my city has too many hills and potholes. I think star lowering by itself will only get you about .7-1 inch if I remember correctly.
Old Feb 2, 2014 | 10:31 PM
2014 BMW M235i
1.5 looks perfect IMO.
Old Feb 2, 2014 | 10:55 PM
Eayacht's Avatar
2003 E320 W211
I agree I think lowering it 1.5 is enough.
Are you using the factory rims or did you go with a bigger rim?
My E class comes with 16" factory rims I recently installed 19". Looks nice but def need to lower the vehicle. I'm going to install eibach springs this week, specs say it with the lower the front and rear 1.5". Mine is a 2003 E-class and it doesn't have air ride suspension. So for about $500 I can lower the car.
I know the air ride suspension is nice but it's more things that will break and cost more money. So I'm fine with with that headache.
Here are a few pics. With factory rims and new ones. I'll post new pics in a few days after I lower it.
Old Feb 2, 2014 | 11:16 PM
2014 BMW M235i
Good idea installing springs instead of cutting them like ricers do hahaha, the air ride suspension is nice but you're absolutely right about it being a weak point on these cars. You're probably better off without it. Btw I really like your 19s lower that beauty, and I think that setup would look great wrapped matte white.
Old Feb 2, 2014 | 11:27 PM
14 550 sedan
Here is more or less how mine looks like on 19s. Height changes a little depending on how the airmatic is feeling. Picture is brightened a little.
Old Feb 2, 2014 | 11:29 PM
2014 BMW M235i
Perfect height!
Old Feb 3, 2014 | 12:02 AM
Eayacht's Avatar
2003 E320 W211
AMGAffalterbach Thanks, negative. No spring cutting here, lol. I don't really like the raped look, if I ever would I'd prob go with matte grey,
Lemonsqueezy that's a bad *** car. I'll be happy with mine after I install the springs.
Old Feb 3, 2014 | 01:54 AM
Lemonsqueezy - thats the type of lowered I want ill take pics tmorrow and post pics of mine I dont want it slammed just a lil above tire
Old Feb 3, 2014 | 02:57 AM
2014 BMW M235i
Going back to your original question, if you lower it but don't go crazy, sure you'll get a little more tire wear from increased negative camber as is natural with the suspension geometry but I don't think it will make that much of a difference in the long run for the rest of your components if they are in good working order and they're maintained. I feel that to a large extent your concerns mostly affect people that are creating badass show cars like 09W211 and Crafty that are static slammed. Getting an alignment after being lowered will probably help minimize problems.
Old Feb 3, 2014 | 09:33 AM
W211
good alignment is the most important thing after lowering a car
and yes i agree, at the height you are talking about you don't have to worry about anything, it's pretty much stock height at the end of the day
Old Feb 3, 2014 | 03:27 PM
Eayacht's Avatar
2003 E320 W211
LemosSqueezy
In the picture you posted with your car on 19' rims. Is that stock suspension ?
Old Feb 3, 2014 | 06:38 PM
14 550 sedan
Um.. yes? The only thing ever done was washer method + star lowering. Everything else remains unchanged.
