Slight vibration at idle when in Drive
Any thoughts on this matter?
1) Jack car disconnect betteries
2) remove exhaust manifold to get to the top bolts on the mounts. IF you can on your engine you may not have to do this.
3) remove motor mount bolts
4) Jack engine
5) remove mounts.
Trans mount is literally 4 bolts, 2 13's and 2 16's, will need jack stands/ramp and one jack and you can have this done faster than it takes you pick up your tools off the ground.
i was about to order an OEM mount on ebay for $50 but i saw that Autohaus has an OE mount for $30 +shipping. just wanted to see if anyone could verify that Corteco is the manufacturer of OE Mercedes mounts?
made a BIG difference, shaking almost completely gone but the drive is sooo much smoother. i'm going to see if i can check the other two mounts see if i need to change them out as well.
Thanks again for the info Dan
1. Motor Mounts
2. Spark Plugs
3. Ignition Coils - this is the issue that I had where I had a vibration at idle that was abnormal that turned into a check engine light and pre-ignition ticking. Took it in right away and it fixed the problem.
