HELP!!!MID-PIPE, DRIVER SIDE, RED HOT!!!!
My theory is that you might have an issue with incomplete combustion and liquid gasoline making its way into the exhaust system causing it to burn up in the hot mid-pipe, much the same way combustion problems can cause melted catalytic converters. A picture, video, further information, or codes would help. It could be a bad situation if it represents a lean situation with the engine as lean mixture = higher EGTs, possibly due to retarded timing.
Ok..yeah i forgot to mention...this car a project car....thing that are broken;...the purge valve is broken...and the mid pipes were very loose...the one that got realy hot was the one i tried to tide...could that be a reazon?...and it gets hot not to long after i start the car....i post a picture tomorrow or ill make a video showing you what i did to the car...thank you
