E-Class (W211) 2003-2009
2003 E500 Brake Pad replacement
Old Mar 1, 2014 | 04:27 PM
Shkhan's Avatar
2003 MB E500 Sport
My first time to replace pads,
Anyone has the procedures to replace front and rear pads?
Thanks in Advance
Old Mar 1, 2014 | 07:06 PM
Eayacht's Avatar
2003 E320 W211
Originally Posted by Shkhan
My first time to replace pads, Anyone has the procedures to replace front and rear pads? Thanks in Advance
Search Forum on how to replace pads, be carful if you haven't done it yourself before
Erico
Old Mar 1, 2014 | 08:33 PM
hayseed's Avatar
04 e55
I think you need to disconnect the SBC connector to disable it so you don't loose a finger or two
Old Mar 1, 2014 | 11:22 PM
Eayacht's Avatar
2003 E320 W211
Yes sir that's correct.
Old Mar 1, 2014 | 11:24 PM
Eayacht's Avatar
2003 E320 W211
Also when you have the car raised and tires off do not open any doors or activate the keyless control. It could set of the SBC and if you have the pads off and your fingers in the calipers you could loose a finger
Old Mar 2, 2014 | 10:26 AM
Craftysince86's Avatar
W211
or you can disconnect the battery
Old Mar 3, 2014 | 03:01 PM
ShinyHypnotoad's Avatar
2007 E350
I like my fingers.
I'd rather pay someone $$$ to risk losing thier fingers changing the brake pads to my car.
Old Mar 3, 2014 | 03:16 PM
AMGAffalterbach's Avatar
2014 BMW M235i
^We've reached the bottom of why I don't like doing safety system related work to my car, not for a matter of fingers as I don't have SBC but because properly working breaks seems like a nice idea
Old Mar 3, 2014 | 03:25 PM
W211
It's fairly easy to NOT open the door while you're doing this... Not to mention you would have to have open the door and then go stick your hand in the calipers to get into trouble.
You need to unplug SBC or disconnect battery before you even start either way to save yourself from the annoying error measge
Old Mar 3, 2014 | 03:27 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Except for the SBC system, brakes are one of the easiest and highest dollar reward job on a car.
While I never recommend anyone doing their brakes without some instruction the first time, I really don't know how anyone with normal mechanical ability, and who takes the time to read up can make any "safety" related mistakes.
2007 E350
Does that mean my 07' also doesn't have SBC?
Because
In May 2004, Mercedes recalled 680,000 vehicles equipped with the system; in March 2005 a total of 1.3 million vehicles were recalled. Mercedes dropped the feature in higher volume models, such as the E-class. Lower luxury class volume models such as the SL, the Maybach and the SLR continued to use SBC
Old Mar 3, 2014 | 03:31 PM
2014 BMW M235i
I'm sure I could do so with relative ease and I would like to think I have the technical understanding to be able to do so, especially considering how much time I spend reading up and learning about Mercedes vehicles and the W211, but I just have an unfounded aversion to doing this type of work on my car.
Because
Yes, if you have a 2007 model year E-Class (well there were no 2003-2006 E350s, those were designated as E320s) then you do NOT have the SBC braking system, all facelift models have a more traditional brake setup which isn't prone to pump failure and many of the really frightening things SBC has had problems with.
