Dual Flywheel question (maybe not Mercedses)
I hear a grinding noise when I press the clutch pedal.
I think the dual flywheel is getting out of order ( the car is a Peugeot 407HDI 2.0 liters).
I was told that a solution could be to weld the two flywheel masses. What do you think?
IS THIS A GOOD SOLUTION?
If welded would it create later more serious problems on the engine/ gear box?
Did someone have any experience and already done it?
Could he post some information, or to tell me where welding spots have to be, any pictures would be useful?
Thank you in advance for your advice
In any case welding a multiple disc is not a good plan. What really needs to happen is pull the clutch find the problem and install new clutch/pressure plate/throw out bearing/pilot bearing.
No short cuts here do it correctly or you are in for more trouble and a tow.
I was able to cut mine & that along with a completely new clutch set up as well as trans bushings & drive shaft bushings everything works fine & as good as new.
