E-Class (W211) 2003-2009
Name of this part,Hep please.
Old May 22, 2014 | 10:17 AM
saulv's Avatar
CharlesStyncOB
Hi,everyone I
I´d like to what is the name of this part,please.
I´m attaching some pics of part.
http://imageshack.com/a/img837/1894/ef5j.jpg
http://imageshack.com/a/img835/5802/hxdm.jpg
http://imageshack.com/a/img835/6100/22ob.jpg
http://imageshack.com/a/img836/6602/ur01.jpg
http://imageshack.com/a/img839/1478/3bu78.jpg
http://imageshack.com/a/img841/9366/c3gjx.jpg
Thanks in advance.
Old May 22, 2014 | 02:49 PM
saulv's Avatar
CharlesStyncOB
thanks for ur time and help, Plutoe.
Im still newbie, because Im very young when I joined and now I bought by my own a mercedes. When I joined I read daily the cases and otherwise to practice my english,too.
My e350 2006 4Matic engine flooded by water,so Im buying a lot of internal parts engine.
So,I bought already some parts of engine,like piston,rods,rods bearing,etc and I need the part pics, because I don´t know how to traslate to english and find it.
Greetings,
Old May 22, 2014 | 03:02 PM
saulv's Avatar
CharlesStyncOB
I think I found the part....
http://imageshack.com/a/img835/1364/f7s5.gif
Old May 22, 2014 | 04:49 PM
vettdvr's Avatar
03 E500 and Corvette
The part will either be a rod bearing insert or main bearing. It takes two of these for each one because they are matched sets.
Old May 23, 2014 | 09:53 AM
saulv's Avatar
CharlesStyncOB
I found the part its came upper and lower, but you have to select from 3 colors:blue , red and yellow. Now is the question wich color to choose.
Old May 24, 2014 | 08:12 AM
vettdvr's Avatar
Each part is made to fit a specific journal size. You will need to know journal size to make the right decision.
There is no scale for color that I know of. At test would be to put a pair on the journal. (caution they are made as a matched pair don't mix them) and check fit, then install one and use plastigauge to determine the internal clearance. About .001 to .003 max would be a good clearance. Greater wrong part, smaller wont' fit.
If you don't have the proper measuring tools to build an engine and get proper fits you might have a real problem with building a good engine.
I would recommend you get local help with someone who has built an engine.
