E-Class (W211) 2003-2009
E55 Amg brakes on E350?
Old Jun 27, 2014 | 02:54 AM
doh!'s Avatar
e350, NSX, CRX
I'm looking at a set of e55 amg brake set up and was wondering if this is a direct bolt on? I have a 2009 e350 amg sport.
Old Jun 27, 2014 | 06:38 AM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
Sort of off topic...but I wanted something sportier on mine and found a thread where someone used the E500 rotors which are cross drilled and slotted. As I recall, at least for my 2005 the E55 calipers required a mounting bracket that was not readily available for use, otherwise it was a direct bolt on.
Old Jun 27, 2014 | 08:09 AM
cm60k's Avatar
While you have W211, they will fit directly, you have M12 bolt in the front knuckle(which caliper mounted), but E55 using M14,
you just need to drilled 2mm to let E55 fit, other than that everything will be fine,,
*I have used E55 front calipers, and used E55 rear Rotors if interested..
ZAYED,,
Old Jul 2, 2014 | 01:48 PM
06E5004ME's Avatar
06 S211 E500 4Matic
It was difficult for me to find replacement calipers for my 06. There are different caliper part numbers for W211 and they have diffrent mounting hardware. Also, make sure your rims are big enough to accommodate the AMG calipers.
To answer your question quick - in my experience, it's not a direct bolt on.
Old Jul 8, 2014 | 12:51 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
The conversion is a direct bolt on EXCEPT you have to machine out 2mm where the carrier attaches to the steering knuckle (kingpin).
Be sure your wheels have the caliper clearance.
Old Sep 13, 2019 | 10:24 PM
Sosyal08's Avatar
W211 AMG
Yes, it can be done...and makes an awesome looking and functioning upgrade. @so.sosyal
Old Sep 14, 2019 | 12:39 AM
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
Arrow
I also did this conversion a year or so back.
Love it. Looks so much nicer than the sport brakes, and the car stops very very well.
They are insanely massive too. It makes the sport brakes and my brembos on my STi look like freaking baby brakes...
-Nigel
Old Sep 14, 2019 | 01:26 AM
Sosyal08's Avatar
W211 AMG
Nigel,
Did you forget already? You walked me thru this job.
Thanks again, buddy!
Old Sep 14, 2019 | 01:28 AM
Sosyal08's Avatar
W211 AMG
If you have sport package there is enough wheel clearance. However I had to upgrade my wheels...by choice on all my vehicles lol. I got problems. Lol
Old Mar 22, 2025 | 04:18 PM
Slave IV's Avatar
2008 W211 E350 4MATIC, 1985 W123 300D Turbo, 2002 C5 Allroad, 2002 B5 S4, 2008 MkV R32
This is a great resource!
Does anyone know if all these same details apply to the 2008 E350 4Matic Sport?
Can anyone explain why the 4Matic version doesn’t come with the same 4Pot calipers as the regular sport?
If no difference other than the caliper, I might be interested in grabbing some of the regular sport 4Pots off someone who changed to AMGs.
Thanks!
Old Mar 24, 2025 | 02:54 AM
rodneypierce's Avatar
2009 e550 4Matic
no, they do not fit the 4matic. Completely different knuckle and caliper. Different mounting points.
Old Mar 24, 2025 | 11:58 AM
Slave IV's Avatar
Thanks for the info! Too bad but I guess it makes my choices easier.
I was going to ask if the AMG spindle has any other differences other than the larger mounting point like if it was also lighter. For those that are able to use these upgrades, any reduction in unsprung weight is a great thing.
Old Mar 25, 2025 | 01:23 PM
timmy0tool's Avatar
2008 S211 4MATIC
bummer. i was just contemplating this upgrade as well, but as i learned in this thread the 4matic front knuckles are different (likely to house the spindle for the front axles?) so the calipers will not bolt on.
i too wondered why the 4matics got the sliding front calipers, and not 4pots...i would imagine a heavy wagon would need more braking power albeit the stopping power on my S211 seems pretty adequate. i just don't like how the calipers look .
Old Mar 25, 2025 | 02:59 PM
Slave IV's Avatar
Yeah, it's a bit disappointing for those of us who want to improve braking performance but for the purposes of this car, it is fine.
But just in case, are the AMG rear brakes compatible with 4Matic or is it also a completely differernt setup? I probably wouldn't do this unless I was going to upgrade the front with an aftermarket Brembo equvalent but just good to know.
For this car, I saw that Goodridge makes a set of SS lines so I'll probably grab those, change the fluid and just stick with the Brembo or Zimmerman OEM replacement rotors and pads next time they need to be serviced and call it a day. Though my digging, it doesn't look like there are many other quality rotor or pad options for this car anyways.
