Front Suspension Noise
EDIT: It appears noise is now constant as long as car is moving. While parked, I pushed down over the left fender and it squeaked briefly, VERY PUZZLING!
It sounds like the springs on a day bed when they are pushed. What could be causing this? Any suggestions would be appreciated.
I recently changed the lower ball joints, not the uppers!
... lifted it up and down.. walked around car one by one making faces
... and suddenly it went away by itself
If you have looked everywhere for the problem can't find anything and haven't repaired anything. It's still there you just haven't looked in the right place.
Now, there is nothing to show trouble other than that squeak, does that mean the shock has to be changed, I mean these monsters are no simple task to do. Not sure how to proceed here!
nahh, those are easy to replace.. You can do it yourself! Or buy them online and btw you need to replace both of them even thought you need only one. I replaced my rear shock a couple of weeks ago.. $88 for parts and $100 for labor. If i had time i would have done it by myself and saved $100
https://www.arnottindustries.com/par...27_gid491.html
I'm also assuming one needs STAR Diagnostics to install these shocks?
