E-Class (W211) 2003-2009
'05 E500 Sounding like a tractor at idle... help!
Old Oct 12, 2014 | 12:56 PM
eezm3's Avatar
2004 G55
Take a look at the video below.... sounds super loud at startup then quiets down a little but still has the clack-clack-clack-clack sound. It sounds like its coming from below the car or the front driver side area... definately not power steering because it doesn't whine, and not sure about motor mounts because revving the engine doesn't make the engine block too much. Pulley? Belts?
Please help!
Old Oct 13, 2014 | 09:10 AM
mthomas981's Avatar
2005 E500
Says 'This video is private."
Old Oct 13, 2014 | 10:30 AM
neverclever's Avatar
06 e500 4matic wagon
probably your a/c pulley
the official way to check is to fit a shorter belt that bypasses the a/c pulley. I bought a pulley from ecstuning for ~160 and replaced it myself in about an hour. You need a good snap ring tool and it helps to remove the fan.
Old Oct 13, 2014 | 10:41 AM
eezm3's Avatar
2004 G55
Video is now public.. thanks for letting me know.
AC is not on in the video.. sound starts right when I turn the car on..
Old Oct 13, 2014 | 11:05 AM
yeah but the pulley is turning even with the a/c off. that is why the test bypasses the pulley rather than just having you turn off the a/c. After watching the video I would say it sounds exactly like my a/c pulley.
Old Oct 13, 2014 | 11:09 AM
eezm3's Avatar
2004 G55
So just buy the shorter pulley? What exactly is the part called! Thanks!
Old Oct 13, 2014 | 11:21 AM
http://www.ecstuning.com/Mercedes_Be...ing/ES1602590/
Old Oct 13, 2014 | 11:27 AM
some people on the forum have replaced the whole a/c compressor in your situation. The reasoning is that the new compressor comes with a new pulley. you can find a compressor for around $450 I think. The install is beyond my abilities and since replacing the pulley only my a/c works fine and is super quiet.
Old Oct 13, 2014 | 11:32 AM
eezm3's Avatar
2004 G55
The belt does not have to be replaced right? Just the pulley from ecstuning?
Thanks!
Old Oct 13, 2014 | 11:40 AM
If the belt is ok you don't have to replace it. With the belt off I would check the idle pulley at the top and the belt tensioning pulley also. just spin them by hand and check for excessive play and funny noises.
Old Oct 14, 2014 | 01:19 PM
ECSTuning's Avatar
Former Vendor of MBWorld
2012 SLS AMG
neverclever,
Thank you for the shout-out and for the business!
I'm glad you were able to find what you needed on our site.
If there is anything I can assist anyone with please let me know!
David
Old Oct 14, 2014 | 07:49 PM
eezm3's Avatar
2004 G55
Any other ideas?
