Rain Sensor / Light Sensor seems deactivated
I have just bought an E320 which had no power to courtesy lights, mirror, sunroof or wiper sensor. I used your video to take the dome down to get the part number and found someone had pulled out the power supply plug. Plugged it back in and everything works.
I should also mention the water intruded in the low spot where the light bulbs sit and enter from the top, there is a funnel shape. For prevention I put a ring of contact cement and clear flexible plastic on the plastic shell over both bulbs to avoid water intrusion in the future. I am aware water should not be getting in there but again it was a crazy storm and I was parked at a weird steep angle. I also cannot remember if the sunroof had been opened for a second or not.
A small about 1mm partial section of a via missing was the source of my daylight/rain sensor problems all along!
I also want to mention it helps tremendously to have a helper hold the OCP while you are plugging and unplugging the wires from it.
I hope this helps someone someday. I would have loved to find this post before all this trouble!
E320 CDI is a love hate relationship....
Nice, but what was the problem Again?
1mm partial section of a via missing??
what is a via?
Mine also stopped working and I know this is after fiddeling with the Overhead OCP I think is called, broke the rain sensor wire, bought new one installed but Command always stay in nightmode display (Set to auto)
AutoWiper runs every 5 sec
Guess need fix some issue in the OCP and then get a Star reset and re-learn the rain sensor..
What is that Little sensor in the Rear Mirror on the front site looking like a microphone??
FYI
Deleted
I have since sold my beloved E320 CDI.
A via is a part of a pc board that is used to pass a signal through all layers. They are round, and I have an arrow pointing to the failure on the via. Before trying to track down a unit with the same numbers to replace it, I'd recommend to check for water damage and possible short and a missing section on traces in your unit. I probably have higher than average soldering skills, so if you don't feel confident repairing traces (if you locate a bad section) take it to someone that is. I had always kept everything working perfectly on the E320 cdi but it was sometimes pretty challenging.
Last month I was away for an extended period of time while my beloved car was parked outside and exposed to the elements -- including some substantial rain.
When I returned from my trip, I realized:
- none of the OCP functions were functional,
- the rain/light sensor was not working, and
- the interior lighting was not working either.
Following recommendations @Mad Davey outlined in this thread, I initially charged the main battery and then replaced fuse #9, both to no avail.
I then replaced the OCP with a used unit sourced on eBay and upon doing so most functionality was restored including: interior lighting, rearview mirror functions (HomeLink, map lights), sunroof switch.
Unfortunately, the rain/light sensor is still inoperable.
The headlights are set to "Auto" and come on even when it is daylight, and the COMMAND unit stays in night (dark) mode.
(Note: If I pull fuse #9 to stop power going to the OCP, the COMMAND unit goes to day (light) mode, and there is no change with the headlights).
I replaced the rain/light sensor wiring cable ("harness") with a new cable and there was no change to functionality.
I also cleaned the windshield around the lens (where I saw no issues), and try the various "reset" procedures, also to no avail.
If I have the rain/ight sensor disconnected, I do not receive any warning messages -- which leads me to believe the OCP doesn't "see" the module.
(Note - I did not receive any messages when the OCP was not functional either though)
I am now contemplating next steps as I continue working this towards resolution, and wanted to get feedback from you all.
And if so, would this be the recommended next step (by going to an repair shop)? (There is a trusted independent MB service shop nearby, as well as a MB dealership).
Or perhaps trying to source and install another OCP unit (that is properly coded)?
Or could the rain/light sensor module itself (not the wire) need to be replaced?
I am watching several used units on eBay. I will likely purchased one to continue diagnosis, but again, I wanted to get feedback from you all before I purchased a replacement.
Or any other suggestions/recommendations on what to do/check next?
Thanks for taking the time to read my post and provide any much needed guidance!
Please let me know if you have any follow-up questions that I can answer to help provide guidance.
I will keep this thread updated with any/all findings and ultimately resolution (once we get there).
David
Take a closer look at the Rain sensor internals... it may feature an unsoldered connector. If so simply resolder 4 junctions then done!
The other thing is you really need a scanner to read what the modules firmware is up to. It's not just a bunch of hardware, it also thinks and communicate through many CAN modules and gateways... so problems often have different fixes.
Given so many details, it takes a fair mind to pin a single cause.
Thank you for the quick reply. I pulled down the rain / light sensor module earlier to get a look at it and note the part number, but I have not opened it up to look at the internals yet. Thanks for the suggestion.
Do you have any recommendations for a scanner? I spent some time this past weekend searching online for a scanner that would be best and possibly include the ability to "code" modules but didn't have any success identifying one that might be best.
Thanks again,
David
connector pins...
We can't see if the pins are properly soldered or simply pressed in...
I do still have the original OCP. I can take some pictures of the board and post them here. Any specific parts I should be sure to include?
Since everything connected to the replacement OCP is functional except for the rain/light sensor, I have ordered a used rain/light sensor (MB P/N: A2118206026) and am hopeful it will be what is needed to fix the automatic wipers/headlights.
If that doesn't do it, I will likely breakdown and take the care to a trusted local independent MB repair shop to let them run diagnostics perform any recoding should it be needed.
It is very frustrating indeed. I couldn't agree more with you about having a love/hate relationship with this car!
Thanks,
David
To confirm, did your OCP lose all functionality like mine did, or was it just the rain/light sensor? I'm wondering if the one trace being shorted (if determined to be the case) would cause all the functions to stop working, or possibly if there are other traces that have also shorted. Guess we will hopefully know more once I get it open! Again, I will share some pics once I get a chance to get into it.
Thanks @Mad Davey !
David
I started this thread 8 years ago and no longer have the car. All I buy is Lexus now because I got tired of chasing two problems at once at any given time, and having nightmares about breaking the transmission or something else. If I had my own large shop complete with lift I may have kept it. The 2005 E320 CDI Engine and transmission may have been the most reliable, powerful and efficient transmission and engine I've ever owned. The 722.6 5 speed and cast iron diesel were both the last of their kind. It really was the rest of the car that required so much that got me to give up. The car was 100% dialed in, in perfect working and serviced order when I sold it at close to 100k, with added bluetooth, new flex disk, new suspension ball joints and arms all around, new shocks, new rear sub frame bolts, new motor mounts, repaired the navigation twice, repaired OCP and more when I sold it. I believe the gentleman that purchased it got an amazing value since most people don't let something like this go easily. I do miss the car but I'm also happy it's gone. Little defects drive me nuts and I will keep chasing them. I only owned the car for about 40k and never have I had to put so much into such a nice running car to keep it perfectly operating for so short of a time.
My situation is different as my original OCP lost all functionality, and after replacing my original OCP with a used one, only the rain/light sensor isn't working. All of the other functions are working properly now.
I took the black cover of my original OCP's PCB and took some pictures. It looks like it may be too far gone, as I see several areas that appear to be damaged.
I am not sure if attempting to clean the PCB and resolder trace is those areas is an option, but would love to hear your opinion.
I couldn't agree more with you about the amazingness and longevity of the 2005 E320 CDI powertrain.
I am the third owner of my car, and it now has 402,500 miles (yes, miles).
The first two owners (who are brothers) were meticulous and I am the same way.
I promised the prior owner I would keep it on the road and in tip-top shape to best of my ability, so I am going to make good on my promise the best I can.
I appreciate you responding to this thread even after having moved on to another car/brand.
I too left little defects drive me crazy. I guess you could say I am now "OCP OCD" and will be until I get this resolved.
Thanks again for the correspondence and your guidance.
David
Based on your examination, I think I will abandon attempting to repair this PCB (from my original OCP), keep the replacement OCP installed, and keep my fingers crossed that the replacement rain/light sensor I've ordered will do the trick. If it doesn't I will likely bite the bullet and take the car I to the shop to get it diagnosed.
Thanks again for your time, @Mad Davey !
oxides bridges galore 😳
The target is 100% clean, no less. All oxides gone, all tiny coper traces repaired then coated/isolated.
Evaluate if that's do-able before spending 3 hours to get to 90% but unable to reach 100%.
Asses if any spots are wasted, start with these though areas.
From there decide to quit or continue ...
