Noise. Intake manifold?
Too many german broads
Recently noticed a grinding noise when accelerating. Stopped by the dealer and went for a drive with the shop foreman.
Since the noise is recently always heard, it was easy for me to address the issue to the shop foreman on the drive.
He stated it may be a intake manifold causing the noise, but that is his speculation. He said it couldn't be any motor mounts or suspension because that's what I assumed that first. Car has 107k miles.
Have to wait until next week to have it looked at since there are no appointments. What do you all think it could be? I have a extended warranty so I hope this would be covered since it may involve the engine...
Any feedback is appreciated, thanks.
14 550 sedan
Could be a long shot but my sister had a grinding noise once and it turns out her entire exhaust system had been shifted an inch or two causing an unsettling grinding noise. It was probably because someone smashed into her rear exhaust tips or she backed it up hard into something lol..
I have a collapsed mount right now. On take off there is a slight delay and you can feel a vibration at idle as you said. I did my own last year. About 50K miles ago.
Dealer states I need new Engine mounts AND a new Intake Manifold due to broken flaps inside, there was a code stored... Just waiting on extended now, not sure how they will take both issues. lol
E320
Also keep in mind flex disc and center support bearings. I recently had collapsed motor mounts replaced and transmission and/or rear motor mount. Just a thought.
Just waiting on the inspector from the warranty to come check out all these issues.
Super Moderator
Is it that stupid plastic piece that failed? If you end up having to repair it on your dime this is a much cheaper route. I would shop around as the kit i linked to doesn't look as good as a few others i have seen that have metal arms too.
http://www.ebay.com/itm/Mercedes-Ben...-/351010558830
