Something is requsting my cooling fan to run at %100 when car is shut off
Thank you.
I had the same thing on my '06 E350 about a week ago. I inspected the coolant reservoir and to my shock I found oil in it! The fan wouldn't always turn on after the car is locked but sometimes it did it.
Turns out it was a defective Oil Cooler because the engine started to run hot.
If that doesn't work you should check the fans connection. Maybe the module on the fan no longer works like it's supposed to. If that's the case i'd like to tell you right away Mercedes doesn't sell the module separately ($900-1000 for the whole fan)
