E-Class (W211) 2003-2009
Keyless Go got wet, anything I can do?
Old Sep 9, 2015 | 10:32 AM
Surfer69E500's Avatar
2004 E500
Forgot it was in pocket while swimming. Now functions dont work.
Do I just need new battery or is the whole thing toast? Thx
Old Sep 9, 2015 | 10:37 AM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
You mean your key fob got wet correct?
Old Sep 9, 2015 | 10:40 AM
2004 E500
what's fob?
Old Sep 9, 2015 | 11:15 AM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
Your key got wet. Take the battery out. Put the key in rice without the back on. Get as much of the board visible as possible and leave the key in rice for 24 hours. Put a new battery in and try it, should work.
Old Sep 9, 2015 | 12:10 PM
cetialpha5's Avatar
Did you go swimming in fresh water or salt water? There are older threads about this out there. Rice is a basic method, silica gel packets are better but not ideal. You'd really want to take the key fob apart, there's threads and youtube videos about how to do it. You'd probably want to use electronic contact cleaner after taking the batteries out and spraying down the whole thing. If it was salt water, the salt will start corrosion and create shorts which the rice/silica gel doesn't really address. Even fresh water will have some minerals that can cause shorts. And if all that doesn't work, you'll have to go to the dealer to get a new key.
Old Sep 9, 2015 | 05:26 PM
2004 E500
It was fresh water. I will try the spraying and rice thing. I have taken apart before for battery already. I will update when complete. Thx
Old Sep 9, 2015 | 05:35 PM
cetialpha5's Avatar
There's also some electronics inside the key fob that doesn't come out when changing the battery. See the videos about changing the key shell, it's a bit more involved than just changing the battery.
Old Sep 9, 2015 | 06:24 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
blow dryer
Old Sep 29, 2015 | 01:02 PM
2004 E500
Update:
FYI....tried all of the above and the thing still won't work even with new batteries. So going to bite the bullet and get new one.
Wow...$475 for ONE new key with Keeless Go function. Expensive mistake.
Old Sep 29, 2015 | 03:34 PM
cetialpha5's Avatar
Did you try all the dealers in your area? I think the price also varies by dealer. One near me has a coupon for 10% off parts.
Old Sep 30, 2015 | 10:08 AM
cmriv's Avatar
Originally Posted by Surfer69E500
Update:
Lost my key fob over the weekend, a little to much to drink. However i do not have keyless go thank god! New key blade and fob 190$ OTD
Old Oct 2, 2015 | 10:42 PM
OnlyGerman's Avatar
Too many german broads
Wow cheapest i have heard for a new key...
