Need a advice on my W211 Blower motor
I installed a new command unit in my my car a couple of months ago and i am going through everything behind the command unit but there is not a lot of wires back there but i must of unplugged something in the process. (it gets pretty cold here in Canada and time to get the fan working -45 C is -49 F. that' s without the windchill.
What i am trying to figure out is if there is a possible relay for the blower motor and its location. possibly can have a bad relay that is not turning on or clicking as they say.
So far what i noticed is that there is power going to the blower 1 being 19 Volts on a pin and the other pin being 13 volts on the female connector that connects into the blower motor. the strange thing is that its not turning the fan on, i tested the fan by battery and it works fine. I also put put power through the regulator and its fine. just when its all connected and installed it just does not work.
I can turn the fan speed up or down from the heater / AC control and it just does not turn on the fan.
