No fuel pressure at fuel rail. Passenger side pump spins up and sounds normal
I knew a bad crankshaft sensor would keep your engine from running, but I didn't think a bad camshaft sensor would. Nonetheless, I put the scanner on it to find out which one it was and replaced it. Nothing changed. Out of the possibility that I replaced the wrong sensor (there are mixed messages on which one is bank A, B, etc), I decided to replace them all (4 all together), and it still changed nothing. There were no other codes. I reset them, looking for a new one to show up, and nothing. No codes, nothing. Cranking it over does nothing. It doesn't even try to start, and no new codes. I don't believe a bad fuel pump or fuel relay always shows up (no feedback to the system), so I assumed the non-starting problem wasn't the camshaft sensor and headed to find out if it was getting fuel or not.
I checked and there was no fuel pressure on the fuel rail, so I suspected a relay since both pumps were replaced a year ago (VDO) and I couldn't imagine one going bad already. I checked the fuse and relay in the trunk, and the fuse is good, and the relay appears to be working fine as well. Both "switched" on poles went to 12 volts when turning the key on.
On the red wire of the main plug that goes to the pump (see attached picture), voltage switches off and on correctly with the relay, and I can hear the passenger side pump turn on and spin sounding normal. So it is a safe assumption this relay is working, and this pump is working or at least coming on.
I never hear the drivers side pump do anything, and I even purchased a brand new one, plugged it in (without putting it in the tank), and it makes no sound at all either. The passenger side spins normally.
So I have come to the following conclusions:
1.) The fuel pump (driver's side) senses whether it is in the tank or not and in gas. (I don't think this is it)
2.) It gets its power from a different wire than the provides the 12 volt to the other pump (the Red wire #2 on the plug) (Don't think this is it unless it gets its power from the pressure sensor plug)
3.) It is so quiet you can't hear it when it is running (Don't think this is it).
4.) It only comes on when it senses pressure form the other pump (passenger side) (I don't think this is it either!
I really am at al loss here as to why it isn't coming on unless there is some logic in the system that controls it beyond having 12 volts provided to it or not. It make sense that would be the case to control the pressure anyway.
Any help would be greatly appreciated! The car is just sitting in a T Hanger for now and I need it back on the road.
If it is of any convenience to others, I have attached some photos. One showing how to by pass the relay, another with location of the fuse and relay. The rest are self explanatory.
Thanks!
You have 2006 models, while I have 2004, but I think the tanks did not change in those years.
So the dual bottom tanks do require fuel to be pumped from passenger side to driver side where is main fuel pickup.
That is done by Venturi effect using returning fuel and I know that on those systems small misalignment makes the Venturi not working (friend drove like that for months when his engine run dry with about 6 gallons of fuel on passenger side).
So my first recommendation would be bringing a can of gas and fill her up.
Hopefully that will be all.
Thanks!
The vehicle cranks correct? crank but no start.... right?
Your rear sam controls your fuel pumps-the ME is what tells it to kick that relay over-maybe you need to do a voltage drop on pins 4 and 17 on the small connector of your ME but this may not be making sense to you....
The driver's side "pump" in purchasing it was much cheaper with all of the goodies attached to it than the plane Jane pump on the passenger side, and it makes no sense. And in looking at how they work, it looks as though the small hose on the bottom of the driver's side pump that Y's off of the hose coming from the passenger side pump could (through Venturi) suck the gas out of the driver's side as well as pump it out of the passenger's side. But unless that is happening, there would have to be a pump on the driver's side as well.
Yes, the pump in the passenger side spins with the switch turned on, and then jumping the relay as well, it sounds very normal and spins at the same rate. I have a brand new pump I connected to the plug and it spins and sounds the same. If there is a pump on the driver's side, then it is doing nothing and even the brand new one I am showing pictures of connected does nothing either.
I had a crank shaft sensor go bad a while back, but if I recall, I still had pressure on the fuel rail. Am I correct a bad crankshaft sensor has nothing to do with the fuel pump turning on? If so, I am wandering if it is the culprit again. It was tricky getting the plug to connect right, but I get no codes thrown trying to start the engine and assume a bad crankshaft sensor would show up, even with the codes reset.
Thanks again for the replies.
Also for the record, Venturi nozzle is a pump.
Older W210 did not have code for CPS work. It would display code when the circuit is broken, but that is all.
One rule of thumb for checking bad CPS (crankshaft not camshaft) was observing tachometer.
Now I am wandering if my main problem is the camshaft balancer from a few things I have read. When the engine first stalled. It would at least try to start, as if it just needed a little more to keep going. But now nothing, doesn't even try to start at all. I hope it isn't a camshaft balancer, but am suspecting that it is especially because of the vibration that was felt before. Fuel does show up at the rail, it is just not under pressure.
Did you fill' er up?
Make sure you have fuel pressure (I think it needs like 60psi, but check it) and than worry about other possibilities.
The "fuel sending unit" is on the passenger side (USA spec) and is an honest-to-God fuel pump. The "fuel pump assembly with integrated fuel filter" (aka "fuel pump assembly") is nothing but a fuel filter and pressure regulator located on the driver's side. Tear apart your old one and see for yourself. If you find different, please post for other user's edification.
You have 3/4 tank of fuel, new pump, you jumped the pump to make sure it runs and you still don't have pressure at the rail?
You probably know better than me, but it looks like when you turn the key on, the starter stays engage for about 5 seconds on its on and then disconnects, or when it detects a certain RPM suggesting it has started, disconnects then. Right now, trying to start it, it just cranks over but doesn't appear to be trying. But immediately after putting in the new camshaft sensor, it was trying and I thought it was going to start. I turned the key, then let off the key and it kept going for several seconds...maybe 5 or so on its own. But in paying more attention to it, it appeared as though it was trying to start, but the starter was still turning it over. And when the starter would "time out", it would stop. In the olden days, this would have suggested a bad ballast resistor, but not here.
It was as if it had enough compression to run with assistance of the starter, but not on its own. So my suspicions were still camshaft sensor related, thinking possibly the camshaft opening and closing was such that it wasn't able to get full compression or power. I tried giving it gas during the time the starter was engaged and it appeared to be trying, thinking that if I could get enough RPM's, it would stay running, but it did nothing, didn't even increase the RPM when it was turning over.
No new codes would generate, nothing. But it wouldn't start. I unplugged one of the camshaft sensors to see if codes would generate from a bad camshaft sensor without the engine actually running, and it immediately generated a bad sensor. So I was at a loss as to what it could be, and didn't give the fuel a thought knowing it had new pumps and appeared to be trying to start. I eliminated anything having to do with ignition, because each cylinder appeared to be working the same.
In initially trying to find out which sensor it was, I got conflicting information, and so I decided I may have replaced the wrong sensor. And so knowing I reset the codes, and even though unplugging a sensor does throw a code, I decided to replace the rest of them and did. After that, nothing. It doesn't even try to start, but it won't throw any codes.
Knowing it has all new camshaft sensors, and now isn't even trying to start, I pulled the cover off the engine, removed the valve cap and used a phillips screw driver to push in the valve on the fuel rail and gas did come out, but no pressure or spray. My experience in the past with this is it should blow out a mist when you push in the valve, not just trickle out some gas. So I came to the conclusion it was fuel related all the time, that the code from the bad camshaft sensor was accurate but not the reason the car stalled.
I pulled the back seat out and removed the cover over the driver's side fuel pump. Turned the key on and tried to listen for it to spin, and nothing. Now I realize that even though as a part it looks like it has a motor, and is even called a "fuel pump assembly", it has nothing but a filter and pressure regulator in it. This has to be one of the best kept secrets, that there is only one pump, and it pumps out from the passenger side, through the driver's side. At the time, I didn't even listen for the pump on the passenger side, thinking that this one (the driver's side) was the actual pump that pumped to the fuel rail on the engine.
So thinking I had a bad pump, or it just wasn't getting juice, I checked the fuse, and it was ok. I removed the relay and shorted it out bypassing it completely. I still didn't hear the driver's side pump spin up (again, I know it isn't a pump now). The passenger side pump is just quiet enough that you have to really listen to hear it spin. I am sure it was running the whole time, but I wasn't looking for it to spin, and it was quiet enough I didn't hear it.
So the thinking was it had to be a pump, even though it seemed so unlikely one would go bad so soon. So I bought new pumps for both sides. I connected electrically the pumps, bypassed the relay and then for the first time heard a pump spin up, and it was the new pump sitting out of the car that I had just bought. And it was the passenger side pump. I didn't know the left side wasn't actually a pump yet.
I reconnected the plug to the installed pump (pump assembly on the left side), bypassed the relay, listened and heard the pump in the tank spinning. I checked, the pressure at the rail, and still gas just trickled out. So not knowing the left side isn't a pump, and not hearing anything spin up inside it, my belief was it was a bad fuel pump on the driver's side.
So I went to the parts store to purchase a new one. But before taking it, they were nice enough to check it out. They checked a total of 3 before coming to the conclusion they had 3 bad new pumps. That is a statement in itself as to how confusing this is.
After reading from you and one other, and realizing it has one pump, and is on the passenger side, I don't believe my fuel pump is bad. I don't have an explanation for why the fuel isn't under pressure, but fuel does get pumped up to the fuel rail. I think with the little amount of fuel that continues to trickle out of the valve, and with the rail valve being higher than the fuel injectors, there should be enough fuel in the injectors for at least partial ignition.
I am going back out this morning to see if there is any spark now, theorizing that the computer has shut it off because of a bad camshaft balancer / solenoid. I hope I am wrong, really do. But it makes the most sense after thinking about it, and especially the rough feel of the car driving down the road leading up to it stalling. Then the engine code reporting a "retarded camshaft sensor". It fits perfectly into the problem.
A stuck solenoid or bad balancer could definitely create the vibration. You can't imagine how much I hope I don't have a camshaft solenoid issue. I am going to take the camshaft sensors off, line up the crank, and then look to see if the circles line up correctly in the wholes. If they do, I'll have one huge smile on my face. If they don't, I'll be one pissed SOB and probably never by a Benz again. I have driven them now for 35 years continuously. But this will put me over the edge. The car has been maintained like you can't imagine. You can't tell it has ever been driven before. You could even eat off the engine, it has been maintained and kept clean that well.
Sorry for the length of this, but I hope it clears up any confusion.
For my 320 engine the harbor freight $19 gauge works, even it says "no Bosch"
I am also going to disconnect the battery from the car for several hours, out of the very small possibility that the computer will full reset itself if it is a problem. It could be a coincidence after disconnecting the plug to the one camshaft sensor, it doesn't even try to start now, But if in doing so, the computer shut things down, hopefully it resets everything back to defaults, even the solenoids if they are bad and will move. Thanks again for your help.
I KNOW YOUR VEHICLE WONT EVEN START-BUT DO THIS SIMPLE VOLTAGE DROP AT THE ME.....
I am having the exact issue as you are and have done the same tests. Do you have any update on what has happened?
Car will run when the fuel problem is fixed.
Somebody in this site hopefully knows.............
Dan
2005 e500
