E-Class (W211) 2003-2009
2008 codes- carly app
Old Mar 12, 2016 | 07:30 PM
mikesignal's Avatar
2008 E350 4matic
Hi all. Just got the Carly app on an ipad and was reading codes on a test drive--2008 w211. Can anyone tell me what all this means? the codes don't make sense to me, except for the misfire code. Thanks.
iPhone Fault Report - Carly for Mercedes - 6.7 - 2 FVA
ID1: DA30F442-A30A-498D-856F-47E864C49056-421-0000006BAF0A0B47-b8d
ID2: 17168740-CC4B-4616-8328-315B8246E806-421-0000006BAF0A1234-1096
INFO: >0E0EC9B6AE9880726552462A1F0971<
2016-03-12 16:42:01
BASE: Series 211 - E Notchback/Van / Baureihe 211 - E Stufenheck/Kombi
BUILD-YEAR: 2008
MODEL: all/alle (-)
FAULTS: 34
ECUs: 38
BATTERY: 14.3V
DEPTH: Enhanced communication
SPEED: normal
CONNECT: Fast Connection
VERSION: 8.1.3
DEVICE: >Michael's iPad< >iPhone OS<
WIFI: >leithguest<
ELM: ><
COM+: >UNKNOWN<
0. Motor Control:
ME - Motor/Engine Electronics (MB: 0034467640):
- : Fault: Combustion misfiring of cylinder 6 has been detected. / Fault: Combustion misfiring of cylinder 2 has been detected.
- Code: 000648
- : Fault: Adjustment of the exhaust camshaft (cylinder bank 1) is performed late.
- Code: 000060
- : Fault: Combustion misfiring has been detected.
- Code: 000632
FSCU - Fuel pump (-):
- ECU not present/no answer
1. ABS / DSC / Brake:
DTR - Distronic (-):
WSS - Weight sensing system (MB: 2118706026):
- Fault: Undervoltage
- Code: 00C001
2. Airbag:
AB - Airbag (MB: 2118701185):
- ECU OK, no fault code
3. Transmission Control:
ETC - Electronic transmission control (MB: 0034464110):
ESM - Electronic selector module (MB: 2115454532):
- Event: Not Relevant! The left rear wheel rpm signal sent from the traction system via the CAN bus is implausible.
- Code: 00P1861
- Event: Not Relevant! The right rear wheel rpm signal sent from the traction system via the CAN bus is implausible.
- Code: 00P1860
4. Instrumentation:
OCP - Overhead control panel (MB: 2118206901):
- : Fault: Either normalization of the obstruction sensor in the tilting/sliding roof has not yet been performed, or an error occurred during normalization. Either normalization of the obstruction sensor in the tilting/sliding roof has not yet been performed, or an error occurred during normalization. The reference values following the teach-in process are beyond the predefined limits.
- Code: 0090E1
- Event: The supply voltage of the control unit is too low (undervoltage).
- Code: 009001
IC - Instrument cluster (MB: 2115404348):
UCP - Upper control panel (MB: 2118218758):
- Fault: The supply voltage of control unit N72/1 (Upper control panel (UCP [OBF])) is too low (undervoltage).
- Code: 009032
- Fault: CAN communication is faulty.
- Code: 009027
- Fault: Not Relevant!
- Code: 009028
RWT - Rear-end door control module (-):
LCP - Lower control panel (-):
5. Light/Rain Control:
HRA - Headlamp range adjustment (-):
XALWA-L - Xenon headlamp, left (-):
XALWA-R - Xenon headlamp, right (-):
6. Heating / AC:
AAC - Automatic air conditioning (MB: 2118302490):
- Code: 009210
STH - Stationary heater with remote control (-):
7. Immobilizer System:
ASSYST Active Service System (MB: 2115408245):
ASSYST PLUS - PLUS Active Service System (MB: 2115408245):
8. Park distance control / PDC:
PTS - Parktronic system (-):
9. Audio / Navigation / Communication:
CTEL - Cellular telephone (-):
TEL / NAVI (MB: 2198202626):
COMAND or AUDIO (-):
SDAR - Satellite radio (MB: 2118701085):
- Fault: The supply voltage of the control unit is too low (undervoltage).
- Code: 00D010
- : Sorry, there is no explanation available
- Code: 00D300
COMMAND / Audio / Handy Interface (MB: 2118204397):
- Code: 00D010
TEL / CD Changer (MB: 2118705390):
UCI - Media Interface (-):
AGW - Audio gateway (MOST network management, diagnosis gateway, radio tuner) (MB: 2118272562):
- Fault: Not Relevant! No or incorrect CAN message from control unit N73 (EIS [EZS] control unit) No or incorrect CAN message from control unit N93 (Central gateway control unit)
- Code: 00D146
- Fault: No or incorrect CAN message from control unit N72/1 (Upper control panel control unit) Not Relevant!
- Code: 00D148
- Code: 00D147
- Fault: The supply voltage of the control unit is too low (undervoltage). Not Relevant!
- Code: 00D010
TELE AID - Telematic service Emergency call (MB: 2034470059):
TELE AID - Telematic services Remote door unlocking , Remote door locking (MB: 2214470059):
TELE AID - Telematic services MB Info , Roadside assistance ( USA, Canada ), Tele diagnosis ( ECE ) (MB: 2034470259):
- Code: 00D101
- Code: 00D201
TELE AID - Telematic service Stolen vehicle tracking (MB: 2034470159):
10. Systems:
AHE - Trailer recognition (-):
LAE [LAA] - Loading floor automatically extendable (-):
BCM - Battery control module (-):
EZS - Electronic ignition switch (MB: 2115452308):
- Event: Undervoltage supply
- Code: 009001
HSW - Heated steering wheel (-):
SCM [MRM] - Steering column module (MB: 2115459832):
MSS - Special vehicle multifunction control module (-):
TPC - Tire pressure monitor (MB: 0038200526):
- Fault: Control module N88 (TPM [RDK] control unit) is not activated.
- Code: 009010
Pass-side SAM - Passenger-side signal acquisition and actuation module (MB: 2115458532):
- Code: 009084
- Fault: Control unit A1 (Instrument cluster) is not transmitting data on the CAN bus.
- Code: 009093
REAR SAM - Rear signal acquisition and actuation module (MB: 2115458601):
- Fault: Circuit 30 has an undervoltage of < 8 V.
- Code: 009038
- Fault: Circuit 30 has an undervoltage of < 10.5 V. This fault is mainly listed when the engine is started. Low voltage only occurs when the fault is erased after engine is started and then appears again.
- Code: 009039
Dr-side SAM - Driver signal acquisition and actuation module (MB: 2115457701):
- Fault: Component M6/1 (wiper motor) is blocked.
- Code: 009052
- Code: 009088
ESP - Electronic stability program (MB: 0365457632):
- : Fault: The supply voltage of component Solenoid valves is too low (undervoltage).
- Code: 0042A4
System diagnosis (MB: 2115408245):
- Fault: Knowledge base configuration incomplete. Not Relevant!
- Code: 00930C
GPS box (MB: 2214460259):
- Fault: Large deviation determined between wheel speed signal and speed computed based on GPS signal. Wheel speed =0 : GPS=20 km/h
- Code: 00D691
CGW - Central gateway (MB: 2115408245):
11. Chassis:
Airmatic (-):
12. Body:
ARWT - Automatic rear-end door / RWTS - Rear-end door closing (-):
DS-LF - Left front dynamic seat (-):
DS-RF - Right front dynamic seat (-):
DSP - Pneumatic pump for dynamic seat (-):
RevETR-LF - Left front reversible emergency tensioning retractor (MB: 2118271345):
RevETR-RF - Right front reversible emergency tensioning retractor (MB: 2118271445):
HS - Seat heater (-):
ESA passenger - Electric seat adjustment front passenger (with memory) (MB: 2118704585):
ESA driver - Electric seat adjustment driver (with memory) (MB: 2118704085):
DCM-RL - Door control module rear left (MB: 2118703185):
DCM-RR - Door control module rear right (MB: 2118703285):
DCM-FL - Door control module front left (MB: 2118701985):
- Fault: There is a discontinuity in the line to component E6/5 (Left exterior mirror turn signal lamp) or the component is defective.
- Code: 00920B
DCM-FR - Door control module front right (MB: 2118702085):
- Fault: There is a discontinuity in the line to component E6/6 (Right exterior mirror turn signal lamp) or the component is defective.
- Code: 00920B
13. Other:
Old Mar 14, 2016 | 02:29 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Is the "check engine" light on?
If it is, it may be worth looking into the cylinder misfires.
Other than that, I'd suggest recalibrating the sunroof/moonroof (do a search on this forum, it seems like a pretty easy procedure with the open/close buttons) will address the roof issue.
The rest of it? Unless you're seeing/feeling a problem, don't sweat it. Check your mirror turn signals. Make sure your speedometer works.
Don't feed the trolls. Sometimes they shower us with extensive knowledge and can be very helpful. Other times, an air of smug superiority seems to overcome otherwise good sense, making their posts more like a golden shower.
Old Mar 14, 2016 | 05:22 PM
mikesignal's Avatar
2008 E350 4matic
thanks....I tried cross referencing the codes off of the MB code list, but they don't match up. It's like the app has it's own codes. I normally use "Dashcommand" for my Trailblazer and Jeep, but it didn't pull any codes out of the MB, so I got the Carly app. So far not happy with it.
Old Mar 14, 2016 | 05:50 PM
2013 ML350 Bluetec
Just for kicks (and since I already have an ELM adapter that I use with Torque Pro) I downloaded and ran the app on my '05 E320 CDI. Something like 40 error/event codes came up. My car runs perfectly. I deleted the app.
You've got the adapter. Download Torque, if you like it send the guy $10 and upgrade to Torque Pro. It only does the basic engine codes, but it is honest about it. Still lets you see stuff live/real time too.
Old Mar 14, 2016 | 06:00 PM
mikesignal's Avatar
2008 E350 4matic
thanks. I kind of figured the app was garbage....As far as I know Torque is Android only. I need to get an android device.
