OEM or Aftermarket Transmission Fluid
thank you in advance for all your help
http://www.shell.us/business-custome...r-locator.html
Shell 134 is just few dollars cheaper and I refuse to be Guinea pig for small savings.
Years on forums show that lot of MB owners, who saved $5 using Zerex instead of MB coolant, sooner or later start overheating topicks.
Was the $5 worth it?
Mercedes approves use of some of their new fluids (motor oil) for older models in spite of less protection, e.g. for some of the newer fluids may offer less protection use of 229.51 oil and 229.52 oils for better fuel mileage. Same with thinner ATF for better fuel mileage.
Little tip: if you jack up the front of the car and leave the rear wheels on the ground you can get another litre or two out of the torque convertor without actually doing the proper TC drain.
Did a full flush on the 722.6 and ran with all shell 134 atf for around 40k before selling the car.
My new car with the 722.9 had a full flush around 23,000 miles ago and is shifting great.
Country of origin (USA vs Germany is no indication of the quality for ATF nor oils today).
Shell advertises semi synthetic while Fuchs advertises Synthetic. Both are likely Group III with Group II additives. The plus is more of a market thing for high VI.
It is MB approved, so are probably 20 or more ATF around the World, that I will not use neither.
You want to go cheaper, owners of W210 have whole success topic about using Valvoline in their transmission.
Again, I am not here to judge the fluid quality, I am just saying that using non-MB fluid proved to backfire in some cases.
You want to test it, go ahead and report back after 30,000 or more miles.
Just like guys on Valvoline did.
Certain ZF transmissions are very unforegiving to DIYers.
Voice of experience here.
relinuca
relinuca
The volume in the cooler is small compared to the tc that many dealers don't drain.
--Kyle
