Left rear wheel super low when parked but no error codes /no spring issues
So my driver side rear wheel seems to sink really low when the car is parked. Significantly lower than my passenger side rear. I had it looked at by a Mercedes repair shop and they concluded my springs were leaking. I then decided to get a second opinion from a guy that fixes Mercedes and he said there was absolutely nothing wrong with my springs. I then took it Mercedes where it sat for 48 hours but never sank as low and it gave off no codes that anything was wrong. As soon as I brought it home the problem started again where when parked it would sink but once I drive it elevated to a normal level. Keep in mind the Mercedes dealership found had worked on that issue 2 years ago ago and fixed it. But even after leaving the car with them this time it never sank and there were no error codes. Any idea what the problem is please ?
When I unlock it it autmoatically starts restoring itself to a somewhat regular height level. I actually get a kick out of watching it self correct.
Received 1,742 Likes
1922 Ford Model T / no OBD
Your airmatic compressor starts with door opening?
Mine will not run unless I start the engine.
How old are the bags?
When somebody says "absolutely nothing wrong" in those cars - it is indication for me that the person doesn't know much about the model.
Those cars are so complex that same symptom can be indication of 4 or even 6 different problems.
You won't go far without some troubleshooting.
The suspension will keep pumping itself up, but now your compressor works overtime, so sooner or later you will have 2 problems from 1.
Received 4,435 Likes
'71 Pinto
Check for leak – air spring, compressor valve, and rear distributer (2). If fine, most likely intermittent internal spring leak. Consider sponsor https://mbworld.org/forums/private.p...newpm&u=226618 ARNOTT replacement https://www.arnottindustries.com/?gc...FU-Cfgod0IoNDA
