E-Class (W211) 2003-2009
How to change park bulb
Old Oct 17, 2016 | 11:05 AM
Arvid's Avatar
Mercedes 1971 W107, W210, W211 2007 E200 k, W213 AMG sedan 2017 modell
E 200 kompressor w211 2007 mod
I can not find out how to take out the bulb. Se picture
The are some plastic tabs on the side of a metal plate.
I can not get it out
Old Oct 17, 2016 | 04:51 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
i reckon those are your headlights H7 bulbs and not the park lights. just pull it. whats with the 2nd photo?
Old Oct 17, 2016 | 05:11 PM
konigstiger's Avatar
'71 Pinto
Correct, here’s the bulb.
Old Oct 17, 2016 | 06:07 PM
Arvid's Avatar
Hi, and thank you for ansver
I have taken out the H7 55 w bulb, (red arrow)but the are not the problem
I think the park light are 5 w or somthing in the middle of the lighthose. (blue arrow) but I can not find how i taken it's out
Old Oct 17, 2016 | 06:12 PM
beejAMG's Avatar
red arrow is your high beam, blue arrow is your park/city light bulb.
twist and pull from the back.
edit: there should be 2 openings the the back of each of your headlights. 1st is for the low beam, 2nd is for the high beam and the park light.
Old Oct 17, 2016 | 06:22 PM
Arvid's Avatar
The metal plate 164-968-00 can not be twist.The are some screws in the top do not alowed to do that.See picture #2
Old Oct 17, 2016 | 06:46 PM
beejAMG's Avatar
not sure if youre opening the same door from the back of your headlights but the parklights should just be twist and pull. not sure what that metal plate is of if your taking a photo of your low beam window from the back.
http://store.ijdmtoy.com/Mercedes-In...ight-a/221.htm
http://www.pelicanparts.com/techarti...eplacement.htm
figur #6 on the second link.
Old Oct 17, 2016 | 07:09 PM
'71 Pinto
Here is OM info, is headlamp OEM
Attached Thumbnails How to change park bulb-capture1.jpg   How to change park bulb-capture.jpg   How to change park bulb-capture3.jpg
Old Oct 18, 2016 | 04:05 PM
Arvid's Avatar
Thank you for answer.
I think the europeian car has different lighthouse.
Mybe I have another problem than a defect bulb. It's not 100% dead
The bulb pulse. Dark 5-10 sek and light 0,1 sek. Again and again.
Are the a computer problem?
Old Apr 14, 2021 | 07:05 AM
tpjnorton's Avatar
2007 W211 E350 4MATIC
Did you ever solve this?
I have the same metal plate on my parking lights.
Old Dec 16, 2021 | 04:14 PM
W211 E550's Avatar
W211 E550
You are wrong my friend. They are not H7 bulbs and are indeed the park lights. Do you know how to take it out to replace the parking light bulb?
Old Dec 16, 2021 | 04:16 PM
W211 E550's Avatar
W211 E550
I have the same problem with my 2007 E550. Does anyone know what that is and how to change the parking light? They are not the H7. It is right under the high beam lamp. The smaller of the two circles. It's making me crazy.
Old Jun 8, 2024 | 10:51 AM
Sjack-Merc's Avatar
E200 and SLK
HI city-light / parking light - called "LED Module" is on the back of that small metal plate and fixed with that Torx screw.
Partnumber is 2119060036 or A2119060036 aka "A 211 906 00 36"
That LED module with circuit board and mounted lens is specific for some of the facelift models (+2007)
The part is no longer regularly available.
A 211 906 00 36
Old Dec 1, 2025 | 06:51 PM
Guernz's Avatar
2007 Mercedes C280 4matic
Did you ever find this part?
Old Dec 2, 2025 | 01:53 AM
Sjack-Merc's Avatar
E200 and SLK
yes. Was able to get one from a company in the Netherlands called Aharon: http://www.aharon.nl/onderdelen
i don’t know if they have more in stock still, but may be worth a try.
Old Dec 2, 2025 | 08:36 AM
Guernz's Avatar
Thanks, how did you remove the old one? Did you have to separate the headlight lens from the housing? I looked at one off of a car, and I wasn’t able to get the old one out because of a clearance issue with the internals.
Old Dec 2, 2025 | 02:57 PM
Heguli's Avatar
2006 E280
You'll need to take the whole light assembly out, as there is not enough room to work. Less of a pain to pull the bumper and light assemly than trying to remove the lens.
