2005 e500 s wont start, please Pros read this
New to the this forum, Not new to Auto,Boats, Motorcycles, and vintage car restoring. very mechanically inclined (very).
Here's the problem:
Recently purchased a 2005 E500 at a estate sale, it has only 16k original miles, The former owner had a little fender bender with his garage, Family made him quite driving.
Cars extremely clean(I mean new) other that the Bumper, fender, radiator and hood.
So I replaced the parts and ready its for paint ,I am trying to start it now. It will crank great but wont start.
What could it be??
What I have done....
First off I checked the fuses, the fuel pump relay also(also jumped it)andI can hear it run. Has new gas.
Only thing is on the dash it reads (car to low), So I checked everything with the Airmatic compressor, fuses and other components with it.
Would that stop it from starting?
Also would the CPS (crank censer) have something to do with it? I read that somewhere.
Had to put a new battery in it also, Battery is good.
Anything I'm missing, don't want to tow it to the dealer for something simple I'm overlooking.
Thanks in advance
DB.
I will check the spark tonight, I was thinking the ride height might set off a disable mode??
I did a 2001 clk this way(wrecked), no problems except the shifter adjustment was the problem.
The 20 amp fuse is good, will test the relay tonight,
Any other fuel fuses I'm missing?Anywhere? just the two in the trunk?
all fuses are good, relay tested and good, fuel pump runs , no pressure at the front of the fuel rail. car will run on starter fluid, full of new gas.
took off cover on pas side fuel tank, full and pump runs, didn't take off drivers side fuel tank cover, Whats in that side? pressure reg.?
I know this is simple , just cant put my finger on it........
Should I replace the thing in the drivers tank?
2005 e500/16k miles/sat 9 months, front end damage/house
Dan
My mechanical genius friend helped me, all voltages are where its suppose to be, pump runs, no pressure,
I havn't charged the front battery yet, Could it be part of it?
The CPS sensor will be suspect if no fuel pump power after the initial start time , And after key turned , the time aprox 1.5 seconds .If no signal from CPS the computer needs to see the RPM to trigger the fuel pumps operation .Hope it helps me i would put the old cps back in .. You can knock the bottom of the tank to see if it starts the pump
I would start by going to the top of the fuel pump, where the feed tap in, and see if there's any pressure coming from the pump. Just because you hear the pump running, it doesn't mean that sediments built up in the tank over time and clogged the intake filter of the pump.
If that's ok then move thru the system, at this point at the very least you can rule this out
I'm no mechanic, just throwing my two cents since you seem to be stuck.
Good luck
