E-Class (W211) 2003-2009
Crunching noise..
Old Feb 7, 2017 | 01:26 PM
plasma's Avatar
2003 E320
Crunching noise..
When I go over any kind of bumps, I'm hearing crunching noise coming from the front of the car. Anyone have a suggestion on what this might be and or where I should look?
Old Feb 7, 2017 | 06:56 PM
justin218's Avatar
Take a look at the springs maybe?
Old Feb 10, 2017 | 03:14 PM
isthisit's Avatar
2006 E320 CDI
Lower ball joint.
Old Feb 11, 2017 | 02:31 AM
nivram13's Avatar
E240 -2003 E55 AMG -2005
Are you hearing the crunching noise at lows speeds?
Old Feb 13, 2017 | 09:09 AM
isthisit's Avatar
2006 E320 CDI
Push down on the fender with the wheel turned in few different dirrections. If you hear a squeaky/crunchy noise it's probably the ball joint. I've replaced two of them. You can confirm if it is the ball joint by jacking up the wheel and checking for any play within the joint. You can use a small pry bar to do that. There shouldn't be any vertical play.
Old Feb 19, 2017 | 02:12 PM
bflaig79's Avatar
2003 e500
I have replaced both front lower ball joints as well as front lower control arms.....thought that would solve my issue. But I still have this crunching/croaking noise during low speed turns or going over bumps. So I'm thinking its the upper control arms
So one or more of the bushings on here are shot and making noise
Old Feb 23, 2017 | 02:14 PM
plasma's Avatar
2003 E320
I tried this yesterday and yes I hear a squeaking noise as well as a weird crunch on the left front. I've changed both the lower ball joint and front control (tension) arm recently, so unless one when bad, it shouldn't be that.
yes, at low speeds
What's the likelihood that it's the strut?
Old Feb 23, 2017 | 03:17 PM
NCTRNL's Avatar
2005 E500 Wagon
I have a noise that you could describe as a crunch but mine is very temperature sensitive. Once it warms up above 50 degrees outside, it stops making noise. Kinda confused...
Old Feb 23, 2017 | 07:38 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
I'm nearly certain there is a TSB explaining that the rubber mounts at the strut top need to be lubed to eliminate this type of noise. Can't find it - maybe Konigstiger will chime in.
