E-Class (W211) 2003-2009
Jerking and Launching when cold
Old Mar 30, 2017 | 03:20 AM
W211Virgin's Avatar
2004 E320
Exclamation Jerking and Launching when cold
As the title explains, I have been dealing with this issue since I have received this car. I have done the following...
Changed tranny fluid
Change filter
Change gasket
Changed electrical connector thingy for trans
Check trans fluid level with that Mercedes metal stick thing
What I have noticed is that the car does not jerk or launch when changing gears, rather right when you take off... I have confirmed this by placing it in gear 1. I have also changed from S to C and it still does this when cold...rarely when warm.
Any ideas?
P.s. this is the most annoying thing about this car so if I can alleviate this situation, I will be forever grateful!
Old Mar 30, 2017 | 01:16 PM
konigstiger's Avatar
'71 Pinto
Ditto, attached bulletin addresses matter inclusive of checking with MB DAS as previously recommended.
File Type: pdf
Old Mar 30, 2017 | 03:46 PM
W211Virgin's Avatar
2004 E320
Thanks for the response, however, I do not suffer from this issue...
And does the torque converter work better once warmed? Cause the car works really well once the car warms up and running...shifts like butter!
I just don't want to throw tons of money at this car...I can do 90% of the work myself, but time is also an issue...
Anyone have a clue how much the diagnostics will cost?
Old Mar 30, 2017 | 09:21 PM
gtferrari's Avatar
'05 ford f150 xlt, '08 ford focus ses coupe, '08 bmw 335xi, '15 ford f150 fx4 ecoboost
i have a cold issue too. doesnt matter if in "c" or "s" from a stop i can ease on and off the throttle. i think it slips up to 1600rpm. at 1600 rpm theres a thud/jerk and then all is normal. like it just went into lock up. nothing again in any other gear, just from stops
Old Apr 6, 2017 | 12:58 AM
ml3504matic____'s Avatar
2015 ML400 4MATIC, 2016 C300 4MATIC, 2014 E350 4MATIC (Totaled), 2006 E350 (Sold)
Same here. When going slow speeds in the morning. It stuffers in the cold only
Old Apr 10, 2017 | 11:22 PM
Tschuss_Bill's Avatar
2005 E320 CDI
I have a 2005 e-320 CDI that suffered from this cold lurching. I researched the forums, including England and Germany. A world of complaints, but not a lot of cures. I took the car to a good dealer. They told me to replace the tranny, the valve body and the torque converter. I replied, ok that's the official response, what's the practical response. The service manager then said, " Take it to a good auto trans shop, have them open up the valve body, if they see clogged screens with clutch material, have the valve body and the torque converter rebuilt. If the passages are clean, have the valve body rebuilt."
My problems were only when cold, say below 50f. No codes.
I took the service manager's advice. Valve body internal screens were gunked up. Both the valve body and torque converter now have the latest sonnax updated parts. There were other things attended to such as bushings. All in it was under $2k.
Some people have claimed that something as simple as changing the conductor plate have cured the problem. Take an iterative approach, maybe you'll get lucky.
Be sure to report back!
PS here's a good article on the subject:
http://www.sonnax.com/tech_resources...shudder-part-1
Old Apr 10, 2017 | 11:27 PM
W211Virgin's Avatar
2004 E320
Thanks for getting back to me!
Honestly, I just can't get myself to spend 2,000 on a car that is worth 6,000. Call me cheap, call me crazy, but I have a feeling I will be replacing this car in about 3-4 years anyways so I may just ride it out or warm up the car in the mornings...in the meantime, I may do the suspension parts being that the parts wont be more than $500.
Then again, the steering needs some TLC as well...ugh...maybe I should just sell it now and move on!
Old Feb 28, 2019 | 09:50 PM
jruerph's Avatar
SL55
I was having a similar issue with the 722.6 trans in my 2006 E320 CDI w/200k. Slight judder/oscillation under hard acceleration or climbing hills... RPMs had a slight fluctuation at cruising speeds...jerky 1-2 shifts when cold...with the occasional shudder coming to a stop. Purchased a new TCC/PWM solenoid on ebay for less than $30 and had it installed at a local transmission shop and now my transmission almost shifts like new.
Old Mar 1, 2019 | 10:10 AM
tjts1's Avatar
C320
Good info thank you. I'm gathering up parts right now to do the repair on my 04 gasser with sane symtom. I have the conductor plate and Sonnax damper kit and I'll add the solenoid. I picked up the $250 MB conductor plate kit with plug filter and gasket for $57 on Amazon Warehouse.
Old Dec 21, 2022 | 12:12 PM
vagt6's Avatar
2004 W211 E320 Sport
My 2004 E320 Sport with 115,000 miles has had this cold transmission jerking problem for at least 20,000 miles. I had the transmission flushed at 100,000, no change. It's fine once the temps are normal in the transmission.
I"m living with it, sadly.
Old Dec 21, 2022 | 12:23 PM
2005 E320 CDI
That is a statement, or is there a question there? Live with it, fine. In doing so, you may be piling up TC Clutch pack crap in your valve body not to mention premature wear to that clutch pack. Based on everything that I learned in this 722.6 adventure is first replace both the conductor plate and the TCC PWM solenoid. Not expensive not difficult. If that doesn't work, buy or have your valve body rebuilt with Sonnax updates. Replace all the solenoids ( I went 'blue top' AMG for those two shift solenoids). If that doesn't work replace the Torque Converter that has Sonnax updates. Or do it all (if you can't "live with it")
-B
Old Dec 21, 2022 | 07:45 PM
F1Fan's Avatar
I think you have the mechanical ability to do this. The Sonnax kit is not that expensive. You might also need more trans fluid. Then it is just having patience and getting after it. Have confidence, you can do it!
