W211 E500 oil level question.
If you're in doubt about how much blood is in the engine, I'd say it is time for an oil change. Change the oil and filter, fill with the recommended amount, and check the level from the dipstick tube with your newly acquired dipstick. Also, take a moment to check what the instrument cluster says at that point. Then you'll know... and you'll be able to check the oil level with your new dipstick whenever you like.
When my car is running, the instrument cluster will tell me I have anywhere from 4.5 to 6.5 quarts of oil.
1. I checked the oil level with the engine stone cold, had not run in two days because I'm doing other work to it. When I start the car the level goes down to 4.5 quarts. Again, no dipstick I can check with...
2. I just purchased the car and even though the dealer said it had a recent oil change I just wanted to check it myself. Without questioning his integrity I wonder whether these sensors can be off by that much.
Dipsticks here if you want: http://www.pelicanparts.com/catalog/...pg4.htm#item10
