oil level question
i drive a 2006 e320 cdi. i have a question about the proper oil level in the car and i'm hoping someone can give me some guidance.
the owner's manual reports the car holds 8 quarts of oil with a filter change. the service menu reported i had 6.9 quarts of oil in the sump. the normal oil level check report this as "oil level ok."
almost a quart low didn't seem ok to me, so i added about a half-quart and re-checked. the service menu now reports 7.3 quarts, but the normal oil level check report says the car is now overfull.
so - if i'm interpreting these correctly, i'm either over-full, or not, depending. anyone have any idea what's causing the apparent discrepancy?
thanks in advance for any advice you can give me.
mark
mark
Same issues..Get a dipstick!
mark
Did you get 6.9 quarts reading when engine was running? If you did then you are ok and now you will have to evacuate that extra half quart to prevent engine damages.
m.
Where did you find it on Ebay?
www.baumtools.com
http://www.automotivetools.com/Techn...9/Product.aspx
The part number is M120-0721 which includes our 648 engine. I am also attaching a file that gives you the oil level while using the dipstick.
When I changed the oil and filter in my cdi, I installed 8 quarts of oil. The next morning I checked it with the FSS and the level was at 7.5 quarts. So I assume the oil filter holds approximately 1/2 quart. With the dipstick, it measured 130mm.
Mike T.
Used the suction pump and got all the oil out, went back to the dash and it read ---qts. Then thru the oil filter housing I put in 7 qts, when back to the dash and it read 6.8 qts. I added an other 1/2 of qt. And it read 7.2 same as before the oil change. So I was happy, also the other menu menu says oil level ok.
http://www.rmeuropean.com/Part-Numbe..._5C1313F8.aspx
look at the second page on the PDF those are the part# for the engine oil tool.
The measuring rod can be found on this site and cost 196.78
http://www.samstagsales.com/mercedes.htm#oil
or the dipstick from here for 40$
http://www.zdmak.com/wbstore/main.as...40-0110&CTMP=1
OM648 or 3.2L CDI needs 8 quarts or 7.5 litres of oil. You should add rest of the oil from 8th bottle.
Went into the FSS menu and before starting it up, the level read 6.1 qts. Once I started it up, it fluctuated between 4.1- 4.7 qts. Is this normal? Do I need to add more?
I just bought the car last month, 2004 E500, and it's not due for service for another 3200 miles.
The service menu check is not for checking the oil level. I found it by accident and enjoy checking the oil that way now that I know what reading is correct. I can also see if it has used any oil with the menu check. The normal way will give you an indication that the oil level is ok and has not fallen below the point that it tells you to add.
You can also start the engine with the service menu oil level indicator and see how much oil is in the sump while the engine is running. If I remember it will show over 5 quarts which means you have about 3 quarts or less in the engine oil circuit and filter.
So far I have not seen the level on the reference menu fall below 6.8 quarts after a oil change interval of over 8,000 miles.
