E-Class (W211) 2003-2009
totaly lost with front headlights
Old May 7, 2017 | 06:11 PM
zack123's Avatar
2005 E500
i got some headlights from ebay http://www.ebay.com/itm/162346094624...%3AMEBIDX%3AIT so i tried to install them but totaly lost with front headlights-18386848_1668481269833464_427442004_n.jpgis the difference compare to old lights. wish i can post pic in here
Old May 7, 2017 | 06:18 PM
zack123's Avatar
2005 E500
new lights come with 3 pin conector and my old one uses 4 pin and another conector right next to it 3 pin one on my new lights dont even exist so my hedlamps dont work what to do is there any way to work around this problem thanks zack
Old May 7, 2017 | 06:45 PM
cMazara's Avatar
w211 03'
Your new lights are not oem.
Your car came with hids?
Old May 7, 2017 | 06:53 PM
zack123's Avatar
2005 E500
just looking at the old lights they are hids now can i make just regular halogen lights work with my curent setup?
Old May 7, 2017 | 07:37 PM
cMazara's Avatar
w211 03'
Return and buy one that are hids
http://www.ebay.com/itm/2003-2009-Me...9X9Z9m&vxp=mtr
The ones you bought are the old style, ones that I send you are the new updated style and claims that are compatible 2003-2009.. before buying send them a message with your vin so they can recheck for you
Old May 7, 2017 | 08:37 PM
zack123's Avatar
2005 E500
as u can tell 4 pins bottom 3 pins tom
this is pic from link u send me so this lights just looking pins will not work for me
Old May 7, 2017 | 09:34 PM
cMazara's Avatar
w211 03'
Can you pleas give me the part number of your headlight?
I believe there's the models without hids, with hids, and afs.
The right ones
This are pricey, see the description where they state the difference, check your ballast before ordering.
I checked again the ones that I sent you and they are 2007-09 models, but they claim otherwise.
Here's a retrofit that explains the difference.
Retrofit DIY
Old May 7, 2017 | 10:41 PM
zack123's Avatar
2005 E500
Retrofit DIY gives me some ideas right now thanks Mazara i think if i swich couple of pins in conector (to match my headlight conector) i may get my headlights to work along with front signal lights i already had small round lights working at list that is something got my fog lights working too.my problem is also that 3 pin conector i have no provision for it on my new lights?? thank you very much for your help
Old May 8, 2017 | 10:13 PM
zack123's Avatar
2005 E500
ok so today i got my answer //////////////////////
New message from: oemassive Top Rated Seller(55,631PurpleShooting Star)
Thank you for letting me know your concern, i have checked on your VIN ############### that your have the 2005 Mercedes Benz E500 AMG Sport package, this is the top of the line model, and the headlights for this AMG package uses the factory HID type headlights not the halogen type headlights. Were you able to get the wiring connected? Please confirm. Thank you////////////////////////////so now since i got the wrong lights need to get another set trying to see if i can return will see what they going to say no big deal 200 out the pocket but can someone will tell me what to look for like part number so i dont do same mistake twice thanks ,Zack
Old May 8, 2017 | 10:21 PM
cMazara's Avatar
w211 03'
Again, This are the right ones
There's no way to make the others work because you need the other connector to give juice to the hids, i'll be a mess just trying. Return them if you can and buy yhe right ones, the one I posted is 2 for one because you not only get the riight ones but you get the updated version ones.
Old May 8, 2017 | 10:46 PM
zack123's Avatar
2005 E500
its funny i was just on ebay looking at them that is only one that i think will work everything is the same from the back and yes i will take your advice there is no way around 1more time thanks for your advice i am little slow hahahahah
Old May 9, 2017 | 05:40 PM
zack123's Avatar
2005 E500
ok new msg today i did buy new set ////////////////////
New message from: fishcake321 Top Rated Seller(37,338TurquoiseShooting Star)
Good afternoon,
Thanks for your follow up message and photo confirmation that you do have Factory Xenon and that you may have AFS from stock.
Just to be 100% sure, may I kindly ask if you can un-install the Control Module (not Ballast) to check the pins to see which one you have?
http://www.speedstersource.com/FISH/...1_03_D2S_D.jpg
If you have the Control Module "B" - then the lights you've purchased should be able to accept all of your transferred HID components. However, if you have Control Module "C" - then you have AFS from stock, which you would need to purchase a pair of OEM control Module "B" and code out the AFS function from your vehicle.
May I kindly ask if you can help confirm with me once more? Thanks again for your support!
Warmest Regards,
Christian ///////////////////////// so i did have old module so i did buy corect module x 2 what he was saying i do have c module and i need to get b module for my lights to work ,now he saying that i have to code out the AFS function from my vehicle. ?????? someone please expl this to me what and how to code out thanks
Old May 9, 2017 | 06:15 PM
cMazara's Avatar
w211 03'
Ok so from the description of the headlights that I told you, the $450 ones, there see the difference.
from my understanding the non-hid version, the one you bought first don't use ballast underneath, the hid version, the one that I send you uses 2 ballast, and the AFS version use a different B ballast.
check the pins on the ballast of the one you removed from your car and post the pic here.
Old May 9, 2017 | 06:26 PM
cMazara's Avatar
w211 03'
Good afternoon,
Warmest Regards,
He wants to know if your car have AFS, post pic of your control modules to make sure. I guess he wants to know before shipping the headlights.
Old May 9, 2017 | 08:12 PM
zack123's Avatar
2005 E500
i did send pic to him my module will not work but i got 2 from ebay that will this link will explain everything so i got right light and right controle module to work with this light/////////// http://www.speedstersource.com/FISH/...1_03_D2S_D.jpg if u go on this link you will see that my controle module is C and i switch them with B module that will operate my lights that i just order
this module will not work if u check the link here posted i need different one B one
my old lights
3pin and 4 pin same as my new order lights
Old May 9, 2017 | 08:15 PM
zack123's Avatar
2005 E500
corect module #B Mercedes Part #A0038206026
# A0028202426
Old May 9, 2017 | 09:45 PM
cMazara's Avatar
w211 03'
So you need the headlight with AFS system, if you order this ones you need two B modules and turn off the AFS in the DAS I guess.
I was looking for AFS headlights and they are over $650 a piece and the old style, not with the 3 horizontal lines on top. So I guess as the description says if you buy two B modules the would work. It'll be interesting to see if the dash trows an error as the AFS will not be available, please post result when you get the modules and install.
Old May 9, 2017 | 10:12 PM
zack123's Avatar
2005 E500
lights coming in 5 days control module in 4 days so wish me luck i learn lot so far but this was only lights on ebay that will fit and work with my car i didnt c anything else
Old May 11, 2017 | 11:09 PM
MacVidMB-V8's Avatar
W209, W124
FWIW, I got LED taillights from fishcake on Ebay a year for so ago.
I kept my old taillights because I expected trouble.
They have been absolutely trouble free, far better than when I was trying to put LED bulbs in.
So the guy sells good stuff.
Old May 11, 2017 | 11:49 PM
cMazara's Avatar
w211 03'
They have been absolutely trouble free, far better than when I was trying to put LED bulbs.
W211 replacement?
mine is avantgarde which came with leds. I want to buy the 2007 led version but don't know if it'll work, in debating on wether buying one used oem side first or a non oem duo... concern is if it'll work.
Old May 12, 2017 | 03:12 PM
zack123's Avatar
2005 E500
geting the lights monday cant wait lol miss driving the car
Old May 12, 2017 | 10:51 PM
zack123's Avatar
2005 E500
http://www.ebay.com/itm/350433837641...%3AMEBIDX%3AIT can i use this for my new headlights????
Old May 12, 2017 | 11:16 PM
cMazara's Avatar
w211 03'
The headlights that you bought comes with low beam and high beam bulbs. no need to buy this.
Old May 17, 2017 | 10:29 PM
zack123's Avatar
2005 E500
before
after so got lights today and everything hook up perfect no mods plug and play lights AAA+
Old May 17, 2017 | 11:15 PM
cMazara's Avatar
w211 03'
Huge difference. Look really nice.
Please post more detailed pictures.
Do this headlights to the 'dance' when you turn on the car?
