E-Class (W211) 2003-2009
Airmatic Nightmare
Old Jul 11, 2017 | 07:38 PM
Garcarcha's Avatar
2007 E550
Airmatic Nightmare
2007 e550
Where is location of rear airmatic leveling sensor?
I've replaced valve block, compressor, relay, fuse, front air shocks, and now rear air shocks. Although everything was working fine prior to replacing the rear air shocks (two weeks after installing front) now the car won't inflate rear airbag. I'm getting an Airmatic Malfunction on the dash and the compressor won't switch on. I'm hoping it's the senor. Any suggestions?
Would anybody here happen to know the part number for this sensor. I can't find one anywhere online, or where to buy for that matter.
As a side note, I had a full head of hair prior to this experience.
Thanks,
Gary
Old Jul 11, 2017 | 08:52 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
I still have all the hair.
You choose the route of dropping parts instead of troubleshooting.
Unfortunately with modern cars you can .... lose your hair this way.
You need to diagnose the system and recommended way is using SD.
When I had troubles years ago and good scanners were hard to find, I install pressure gauge on air line. That allow me to figure out all the problems.
Now you do have hard code or burned out compressor. When there are ways to do it oldfashion way, now is good time to buy good scanner.
Old Jul 11, 2017 | 11:08 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
At least he doesn't have to worry about replacing all that stuff for awhile since he just threw parts at it.
Old Jul 11, 2017 | 11:32 PM
ItalianJoe1's Avatar
2003 CL 600
Rear sensor is in the center near the diff, on the rear subframe. It's only got one vs. the left/right setup in the front.
It won't cause your compressor to not turn on, you should have the car tested properly before you just launch more parts at it.
Old Jul 12, 2017 | 11:16 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Garcarcha,
PM me your email address and I can send you some troubleshooting info. Bottom line, however, is you need the proper diagnostic system; it will send you straight to the bad part and, in the long run, saves a crap-ton of money and aggravation.
Old Jul 13, 2017 | 03:13 PM
Garcarcha's Avatar
2007 E550
Originally Posted by bbirdwell
Garcarcha,
Thanks bbirdwell. I appreciate your efforts.
Old Jul 13, 2017 | 03:21 PM
Garcarcha's Avatar
2007 E550
I'm really surprised by some of the responses to my first request on MBWorld. I thought this was a forum where I could go to for help. How quick most are to "assume" and insult. No one is throwing parts at anything. In fact everything has been diagnosed along the way, with a scanner. A big thanks to bbirdwell for actually offering to help!
Old Jul 13, 2017 | 04:09 PM
Strigoi's Avatar
Oh, so we should just assume that you didn't throw parts at it and had the car properly diagnosed? Was it diagnosed by a dealer/shop or did you just use some scan tool? Most dealers could tell you exactly what the issue is with what they use. You mentioned nothing about scanning anything or having the car diagnosed in your original post, which is all we had to go off of. From what you posted there it 100% sounded like you were just throwing parts at the car trying to fix it.
Old Jul 13, 2017 | 04:29 PM
Garcarcha's Avatar
2007 E550
Perhaps you shouldn't "assume" anything! I was asking for the location of the rear sensor not what you assumed I did or did not do. And for the record, my scanner didn't indicate most of what the professional scan did. Thanks for all of your expert advice and help.
Old Jul 13, 2017 | 04:36 PM
kajtek1's Avatar
So now you blame us that we took your note about loosing hair seriously?
I think you've got much more help than we got paid for the advice, so who should be the one complaining?
Next time you think you have only 1 question - google it and end of the story.
https://www.google.com/search?q=rear...Xt2HmbnZsvWSM:
Old Jul 13, 2017 | 04:53 PM
Strigoi's Avatar
You're a sensitive little fella aren't you?
Old Jul 13, 2017 | 05:09 PM
Garcarcha's Avatar
2007 E550
Not at all. I just don't take crap from jerks.
Old Jul 13, 2017 | 05:13 PM
Garcarcha's Avatar
2007 E550
No, I thought knowing all of that information might have an impact on your advice and save you the trouble of asking additional questions.
Garcarcha's Avatar
2007 E550
Strigoi's Avatar
We're jerks for saying you threw parts at the car?
Old Jul 13, 2017 | 05:16 PM
Garcarcha's Avatar
2007 E550
Garcarcha,
Thanks for all of your help and advice bbirdwell. I really appreciate it!!!!!!
Old Jul 13, 2017 | 05:19 PM
Garcarcha's Avatar
2007 E550
No. You're a jerk because of your condescending attitude. No go harass someone else. I don't have time for people like you.
Old Jul 13, 2017 | 05:24 PM
Strigoi's Avatar
But I'm having fun watching you get kind of worked up over this. I'm bored at work and need to entertain myself somehow.
Old Jul 13, 2017 | 05:39 PM
nivram13's Avatar
E240 -2003 E55 AMG -2005
2007 e550
Thanks,
Gary
Part number 0105427717
Location: https://mbworld.org/forums/w211-amg/...-location.html
Old Jul 13, 2017 | 06:44 PM
Garcarcha's Avatar
2007 E550
Originally Posted by nivram13
Thanks for your help! Really appreciate it!
Old Jul 15, 2017 | 12:18 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Garcarcha, if you've replaced multiple components in the suspension, especially ride height sensors, you're going to need to re-calibrate your suspension. To do that you are going to need access to a STAR diagnostic system and download an inclinometer app to your cell phone. Plan on about an hour to re-calibrate but it is not difficult at all.
See here for info:
https://mbworld.org/forums/w211-amg/...ml#post6862688
Old Nov 4, 2017 | 02:08 PM
Mr.ssg178's Avatar
2000 S430
No help on this page, just a bunch of I kow it all and a pissing match
