oil extraction, no dipstick?
2003 E500
Hi guys. I have been lurking for a while and have used the search function extensively but I cannot find the answer to this. Since the 2004 E500 does not have a dipstick, how do I use an oil extraction method to cahnge the oil? If I remove the filter first, does this give unobstucted access to the bottom of the engine and the oil pan? I also read that there is an access in the rear of the engine that MB techs can use to check the oil level using a dipstick. Is this true and if yes where is it and could someone post a pic. [URL=http://business.baylor.edu/Richard_Easley//autofaqs/getoil.htm] This is the link I followed , but the car in the demo actually has a dipstick. Sorry if this has been posted before, but I just can't seem to find this answer. TIA
**SOLD***2003 E500
There is a dipstick type tube toward the rear of the motor next to the firewalll. You will see one for tranny and one that is not marked with a cap. That is the old tube.
2003 E500
Thanks for the reply. Just one other question. Do you guys use plastic tubing down the dipsick hole or copper tubing as is mentioned on the last method of changing oil on the post I referred to in my initial post?
I don't think this is exactly the setup, because the car in this article has a dipstick. but at least this shows the use of the topsider, and mentions how to flare the end of the siphon tube. as the other poster said, just be sure you don't drain the transmission!
http://www.mercedesshop.com/diy_oil_change2.htm
2003 e320
my link is dead too. http://www.mbusalearning.com/w211ele...ound/index.htm doesn't work. the main menu is at http://www.mbusalearning.com but like what others have said it's restricted. only wish i was able to download videos before they closed access.
2003 E500
In the picture I only see one tube. That's the one I found at the rear of my car-the one with a tabbed cap on it. The cap is only about 2-3" long, so I assume that is for oil and not to check tranny fluid. I will drain only a little out to be sure before I do the whole drain process. Thanks for your input!
Here are instructions for draining oil from an M113 engine using the Topsider extraction device. It even comes with pictures. Although it shows the dipstick, later versions should have the dipstick tube in the same location...I assume.
2003 E500
I guess I'll have to take the air cleaner off then and take a look. Either way I'll only drain a little out at first just to make sure I've got the right one. Wouldn't want to end up posting on this board under stupidest things you've ever done : "well I once drained out all my tranny fluid thinking it was oil and then tried to add another 8 qts of oil through the correct oil fill site. The car smoked like hell and the tranny seized up on my first ride!!"
Plus, MB actually designs their engines to be "drained" from the top, why do you think they bothered putting the filter on top.
I think in Germany this is how their equivelant "Jiffy Lube"s change oil.
300D turbo, E 300 D
MikeF,
I am in the same boat as you, my '04 W211 has no dipstick and only one dipstick like tube near the firewall, passenger side of the car.
Is this the oil or transmission dipstick tube?
03 E500 and Corvette
You really don't need this tube to change oil.
I do as conventional,, pull the plug, drain, and refill through the filter housing when changing the filter.
I guess I'll have to take the air cleaner off then and take a look. Either way I'll only drain a little out at first just to make sure I've got the right one. Wouldn't want to end up posting on this board under stupidest things you've ever done : "well I once drained out all my tranny fluid thinking it was oil and then tried to add another 8 qts of oil through the correct oil fill site. The car smoked like hell and the tranny seized up on my first ride!!"![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
Imagine if MB had the wisdome to put a LABEL on these as EVERY OTHER car maker does.
You haven't looked down far enough to see the other tranny tube. It will be located under the manifold air intake about 6" below it. The oil tube will be higher and to the right of the vehicle.
