E-Class (W211) 2003-2009
08 E350 M272 Normal Engine Noise? (video)
Old Sep 17, 2017 | 04:28 PM
coronat's Avatar
08 Mercedes-Benz E350, 09 BMW 528i
I have an 08 E350 with the M272 engine. I was changing fluids and noticed a possible tapping sound. Any idea if this sound is normal?
Oil level is and has been fine (although the oil filter housing is leaking), oil changes have been done every 5k miles and have only used Castrol EDGE 0w40 European formula.
There hasn't been any CEL/MIL and no oil pressure issues (as far as the car has shown via codes).
Old Sep 18, 2017 | 11:16 AM
ps2cho's Avatar
E
Sounds normal to me - how many miles?
Old Sep 18, 2017 | 07:50 PM
coronat's Avatar
Thanks, hopefully it is. It's clocking at around 96k miles.
Old Sep 19, 2017 | 03:03 PM
ps2cho's Avatar
E
you could try using mobil1 0-40w next change and see if it makes any change. Doesn't sound concerning
Old Sep 20, 2017 | 01:01 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
see how the audio pitch changed as you moved camera? Are you talking about that howling noise? I sorta hear a howl near the intermediate idler pulley..... or maybe the audio quality is misleading....
Old Sep 23, 2017 | 01:35 PM
mcleantmw's Avatar
2003 E500 Benz & 2015 BMW M235ix
Fuel Injectors?
May be the fuel injectors........normal. A couple years after I bought my car in 2005 I also thought I heard possible problem noise from engine. The MB Dealer and third party MB Repair shop all said "normal" sounds. These engines are a little clanky from injectors etc.
https://youtu.be/9zqXhxud53s
Old Sep 23, 2017 | 07:06 PM
coronat's Avatar
Okay thanks. I just did an oil change this weekend (needed to do one anyway) and it didn't make a difference. I'm starting to lean towards this is normal. I've look at YouTube videos and other owners had posted M272 engines with very obvious knocking.
Old Sep 23, 2017 | 07:09 PM
coronat's Avatar
It's not the howling noise. I do have a belt/pulley kit that I've been meaning to install (includes idler/reflector pulleys, belt tensioner, and belt).
I'm starting to lean towards this is normal. I've look at YouTube videos and other owners had posted M272 engines with very obvious knocking. It's a very subtle taping noise, but I can't seem to locate it.
Old Sep 23, 2017 | 07:14 PM
coronat's Avatar
Are you referring to your E500? Isn't that a different engine (M113)? I'm taking it in to my indie MB shop this Wednesday to have the camshaft position sensors (4x) and magnets (4x) replaced and will ask them about the noise. They were working on this car 1-2 months ago and didn't notice any odd noises (then again, neither did I).
