E-Class (W211) 2003-2009
Fuel pump in 2008 E350 costs over $3,000.00
Old Oct 22, 2017 | 11:37 PM
cetialpha5's Avatar
Originally Posted by Sleeper Benz
How can you tell if the Vehicle is PZEV ? My build sheet doesn't show a code 917, but does show a code 915 "Fuel Tank with Larger Capacity"
I assume I should contact a local dealer to see if any recall service has been performed regarding the fuel system?
As Konigstiger mentioned, it's just an extended warranty. Do not contact your dealer as there's no recall. It's basically a 15 year extended warranty for non Pzev W211 cars with unlimited miles. Pzev already had a 15/150k warranty on the tank so it's worse if you're a Pzev with over 150k. On a 2004, coverage probably expires sometime in 2018 or 2019 depending on the in service date of the car which you can either get from the VMI at a dealer or the carfax. I would fill up the gas tank and sniff around the back seat to make sure you don't smell gasoline. I'd double check again just before your 15 years is up.
Old Oct 23, 2017 | 01:24 AM
allencunningham's Avatar
e350
I am a 2008 PZEV. I have already paid an Indy $3200 for fuel pump and tank which I would like to get reimbursed. I was told to take the work order down to my local MB dealer and see if I can get it reimbursed.
Old Oct 24, 2017 | 02:53 PM
My_E350's Avatar
2008 E350
If your PZEV you do qualify for a 15 year/150k mile warranty. I head a dealer replace my entire fuel tank a few weeks ago under that warranty.
Old Mar 7, 2021 | 04:57 PM
Kelvin Bellrose's Avatar
2007 CLK550 Coupe, 2003 CL600, 2012
2008 e350
Fuel pump from Rock auto 80 bucks time to replace 30 min
Old Mar 7, 2021 | 09:42 PM
tjts1's Avatar
C320
Are you daft?
Old Mar 7, 2021 | 11:05 PM
Originally Posted by tjts1
Are you daft?
What's different with a pzev?
Old Mar 8, 2021 | 03:36 AM
  #32
ot1's Avatar
ot1
2006 E320 CDI
it would be a good idea to read the entire thread before making daft comments...
Old Mar 8, 2021 | 07:43 PM
  #33
Have you seen pictures of what the tank looks like under the rear seats? I would like to see what it looks like. Since no one has left any pictures or vin numbers you are only going by what the mb crooks are telling you.
Unless you can show me proof that the tank is sealed then I call bs.
Old Mar 8, 2021 | 08:26 PM
  #34
tjts1's Avatar
C320
Do your homework before running your mouth.
Old Mar 8, 2021 | 08:38 PM
  #35
Guess that's the price you pay for being green. I'm sure Gretta is pleased with their choice.
Old Mar 8, 2021 | 09:31 PM
  #36
gogydm's Avatar
08 E350
And why do they deserve to pay thousands?
Old Mar 8, 2021 | 09:37 PM
  #37
Because it costs money to save the planet
Old Mar 8, 2021 | 10:48 PM
  #38
cetialpha5's Avatar
I believe the Pzev tank is different from the regular tank so it can have the Pzev designation. In theory it might be possible to use the non pzev part in a pzev vehicle, it just wouldn't qualify as pzev anymore. But if you're paying the bill instead of Mercedes, that would probably be a much cheaper way to go than the official way.
Old Mar 9, 2021 | 09:00 AM
  #39
tjts1's Avatar
C320
Getting the fuel pump and sender out of a PZEV fuel tank involves cutting the tank open then welding it back together. Yes, it's steel. Good luck with that $80 fuel pump idea.
