SBC AND PART NUMBER and compatibility
#52
I cant seem to get this part. What are the interchangeable part numbers?
Sbc number
On chassis WDB2110612A627625
Abit confusing as a search by VIN here shows that is should be using A 005 431 73 12 HYDROPNEUMATIC UNIT or A 005 431 81 12 HYDRAULIC UNIT
#53
Received 4,438 Likes
'71 Pinto
#54
I recently purchased a 2005 e320 CDI. Scan of SBC showed an actuation count of about 58k, which I thought was insanely low for a 2005 with 195k miles. The SBC part number is A 009 431... This would seem to suggest that this unit has been replaced (and I can probably trust the 58k actuation count number), yes?
On a 2006 e320 CDI that I picked up as a parts car I was not able to glean the actuation count. Part number starts with A 005, Likely original?
#55
'71 Pinto
Replaced or reset.
#56
I managed to find an SBC unit with the exact part number as the faulty one in my car. There should be no reason it should not work right? I am so nervous because I made the mistake already of purchasing an SBC unit that had a different part number. I'm a bit paranoid now. Can you please confirm that replacing with a unit with exactly the same part number as my old one will work. Thanks in advance.
#57
'71 Pinto
If not faulty, see attachment covering replacement.
McDee (01-11-2023)
#61
'71 Pinto
#62
'71 Pinto
#64
'71 Pinto
#65
mercedes e320 elegance
https://techniczentrum.com/en/abs-pu...265960019.htm this mentions hardware 4q and mine is 2q so would it still work l
#66
Need compatible part number for SBC pump
If this is your VIN WDBUF26J05A579387 attachment shows compatible part #s, 0054313312 is not listed.
#67
'71 Pinto
#69
Hi Konigstiger,
I'm looking for a replacement SBC unit and can't seem to see this part number already posted.
VIN number: WDB2110161A718985 and SBC part number: A0084313912
Much appreciated!
Much appreciated!
#70
SBC replacement
#72
2005 Mercedes-Benz E320 W211
Sbc compatibility
Greetings!!! Can u look up my compatible sbc. Vin WDBUF82J15X168473. Model 211.082 SBC number 0054313312
#75
SBC/replacement part number
Hi, My VIN is WDB2112801X169053 for S211,E240. What is compatible SBC part #? The numer of mine sbc is A005 431 33 12Thanks in advance.
[/QUOTE]
[/QUOTE]
