SBC AND PART NUMBER and compatibility
Received 4,421 Likes
'71 Pinto
'71 Pinto
'71 Pinto
Good evening konigstiger
I hope i find you well, please assist me as well. I need to replace the SBC Unit on a Mercedes Benz E320 W211 2004 Model with the following details;
VIN WDB2110652A662335
SBC A 005 431 50 12 Q3
0 265 250 082
0 265 250 082
'71 Pinto
#32
WDB2110652A662335
Good day
I eventually found the exact SBC Unit (A 005 431 50 12) as the one currently fitted on my vehicle on ebay, please confirm if it will work or if it was a wrong unit fitted on my vehicle in the first place. You previously said the SBC part number for WDB2110652A662335 is A 005 431 82 12 and A 005 431 50 12 is also not on the list of compatible part numbers you sent to me.
Thank you.
Thank you.
#33
'71 Pinto
I posted what ‘MBUSA’ EPC shows for your VIN if 0054315012 was installed you should not have a problem replacing it with the same part #.
#34
#35
Mercedes Benz e320 2000 Avantgarde
Sbc pump compatibility
Hi konigstiger could you please tell me what the compatibility is for my vin number for the sbc pump WDB2110612A474318 would this mean that any of the numbers in the compatibility would work also if I installed an sbc with different numbers would it work but no cruise control is that correct
#36
'71 Pinto
#37
Hi Konigstiger,
I'm looking for a replacement SBC unit and can't seem to see this part number already posted.
Do you have the time to check it in MB EPC? VIN number: WDB2110161A430452 and SBC part number: A0054310512Q2
Much appreciated!
Much appreciated!
#38
'71 Pinto
Concerning part # search 0054310512, here’s what EPC shows:
Baninto (09-08-2022)
#39
Think I bought the wrong part
Hi
I have a faulty SBC W211 e240 VIN: WDB2110612A650395. I bought a used SBC W211 e320. Part numbers are different. I'm getting conflicting info. Some people say I can use the e320 SBC and others say it won't work. I need some clarity please.
Here are the part numbers:
E240 SBC 005 431 7212 Q1
E320 SBC 005 431 9612 Q2
Please let me know if I have just wasted a lot of money and bought an incompatible SBC. Thanks.
#40
'71 Pinto
Here are compatible part #s for your model/model year:
Not finding 0054317212 in MBUSA EPC, 0054319612 has 03 & 04 software:
#42
'71 Pinto
Yes.
#44
Sbc part number a0054313312 mercedes w211 e220cdi
Hi
hopefully you guys can help me , I am uk based so sbc pump has no warranty and has failed , I am trying to find replacement part numbers as mine no longer exists a0054313312.
can someone search from my vin number to make sure I get the right numbers
vin WDB2110062A596166
Will this work with my current esp module or does it need to be swapped as well
obviously understand it needs to be coded in with the right software
thanks in advance for any help
#45
'71 Pinto
#50
'71 Pinto
3812 certainly is if you compare codes to 2612. 7912, 9612 correct model year have vendor confirm compatibility.
