E-Class (W211) 2003-2009
No Brakes, SBC, ESP
Old Nov 19, 2017 | 07:51 PM
kirkgrau's Avatar
2006 E350 4-Matic
No Brakes, SBC, ESP
2006 E350 4Matic, ~200,000 miles - Owned since February without any real issues. Took it out this weekend and had 2 warnings come up on the cluster. ESP - Visit Workshop and Reduced braking Depress pedal to floor (paraphrases, second message was in red). Tried the brakes and had no brakes at all. Turned around to come home and noticed that car was in a mode that limited it to 2nd gear (maybe third, presumably to keep speed down). Got to the driveway, coasted to a stop, and turned it off and then started again. Did not have any messages. Haven't driven it since, don't really want to not have brakes at some critical time. I see the sticky thread about the brake switch and might replace that since it is cheap and easy, but symptoms don't seem to quite match up. Wondering how to go about diagnosing this.
Any thoughts and/or suggestions?
TIA,
Kirk
Old Nov 19, 2017 | 10:48 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Put it on a diagnostic system. This is your life and the lives of anyone in your car. SBC is fantastic when it works as designed but you run the risk of injury or death when it fails. You can replace it yourself if you are mechanically competent but expect to spend ~$1000. Might be as simple as a bad accumulator or ground strap, could be a major system failure. Don't try to save money on this one.
Old Nov 20, 2017 | 02:18 PM
LexBrett2's Avatar
2007 Mercedes E550
YIKES,
Definitely get your car scanned.
It could be something simple or something very complex.
How many miles are on your car??
Old Nov 21, 2017 | 10:21 PM
Shack1's Avatar
06 E350
Originally Posted by LexBrett2
YIKES,
200,000k stated in the OP
Old Nov 22, 2017 | 09:19 AM
LexBrett2's Avatar
2007 Mercedes E550
Oh, sorry, I missed the mileage on your initial post.
If it were my car, I would change the brake switch.
I even keep an extra switch in my car just in case.
Def get your car scanned and please let us know.
Good luck!
Old Nov 24, 2017 | 07:25 PM
kirkgrau's Avatar
2006 E350 4-Matic
Took the car into the dealer to get scanned. They say it is the SBC pump and that requires the replacement of the whole unit. Found a good write up on replacement procedure so probably going to do it myself. Any hints to ensure success?
Kirk
Old Nov 24, 2017 | 08:31 PM
Shack1's Avatar
06 E350
[QUOTE=kirkgrau;7319863]Took the car into the dealer to get scanned. They say it is the SBC pump and that requires the replacement of the whole unit. Found a good write up on replacement procedure so probably going to do it myself. Any hints to ensure success?
Kirk[/QUOTE
What did they charge?
Old Nov 24, 2017 | 08:51 PM
LexBrett2's Avatar
2007 Mercedes E550
Kirk
Hey Kirk,
Did you notice that the SBC install requires reprogramming from Mercedes STAR/XENTRY?? The diy seems doable, except most people don't have access to this very expensive equipment. Thoughts??
Old Nov 24, 2017 | 10:07 PM
cetialpha5's Avatar
Hey Kirk,
Either pick up a knock off Star system and sell it afterwards, or just DIY it and then take it to the dealer afterwards to just have them code it. Should be cheaper than having them do the whole job.
Old Nov 26, 2017 | 07:16 AM
kirkgrau's Avatar
2006 E350 4-Matic
I saw the part about needing the diagnostic equipment...
Eeuroparts.com has a system dedicated to brakes that can be rented for about 25 USD.
Old Nov 26, 2017 | 03:31 PM
nivram13's Avatar
E240 -2003 E55 AMG -2005
Hey Kirk,
Replacement SBC units do not require any coding or programming just ensure you get the correct SBC unit that matches your VIN, you will however need STAR to complete the brake bleeding process and SBC deactivation.
Old Dec 2, 2017 | 10:37 PM
BryanW203's Avatar
Has anyone used Module Master to repair the SBC unit. My 06 E500 wagon has the lovely a7/3n1 internal fault. I have a clone Star system.
Old Dec 2, 2017 | 11:21 PM
Shack1's Avatar
06 E350
So an indy shop should be able to this repair?
How many miles?
Old Dec 2, 2017 | 11:24 PM
Shack1's Avatar
06 E350
Looked on their site and could not find it?
Old Dec 3, 2017 | 12:09 AM
BryanW203's Avatar
How many miles?
217k had flawless dealer history till 200k. No SBC replacement on VMI. I have pretty much the same issues as the OP. I installed a new stop switch, got a new battery since mine was on its way out, and even tossed in a used ESP module, found the exact one for $80 shipped. Still have the dreaded red brake warning.
Old Dec 3, 2017 | 02:39 AM
Shack1's Avatar
06 E350
That sucks I’m only at 45k miles but already have the balance shaft issue.
Old Dec 16, 2017 | 06:46 PM
kirkgrau's Avatar
2006 E350 4-Matic
Here is a link to the brake tool
https://m.eeuroparts.com/Parts/79472/Electronic-Brake-Service-Tool-EPB-SBC-EP21RENT/
