Need Advice- Have had the dreaded droning/humming noise after bad radiator...
so about 18 months ago I started hearing the dreaded droning/humming noises when at 1500-2500 RPM and found that I still had the faulty radiator from the 2003 E55 that was known to leak glycol into the transmission. I had the radiator replaced and had a thorough transmission flush from the mechanic. That was 18 months ago and when I first got it back there was a slight humming/droning noise but it eventually got worse.
Now over the last 6 months its been the same humming/droning noises but it hasnt gotten progressively worse and its been still driving with no breakdown over the past 18 months. My understanding is that if the glycol did the damage then my transmission would be long gone by now isnt it?
Is it possible that just the torque converter needs replacing and I will be fine? Or given that the droning was lessor at the beginning right after the flushing it means that the transmission needs to be flushed again? I just dont want to be throwing money away on things that wont fix the true issue.
If I keep driving it will the torque converter ultimately fail or just always run with that droning sound?
Any help or plans of action for this is appreciated
if glycol was somehow still in transmission wouldnt it have killed my transmission many months ago?
thanks
thanks
