E-Class (W211) 2003-2009
Shifter code P1856
Old Apr 10, 2018 | 04:16 PM
scott099's Avatar
E500
Shifter code P1856 *FIXED*
I cannot get back into reverse or park with my foot on the brake. if I take my foot off the brake (oddly enough) it goes back into reverse or park just fine, every time
car is also in limp mode, trans won't shift
do I need the whole shifter assembly, and if so what is the part number for that? thanks
Old Apr 10, 2018 | 04:35 PM
konigstiger's Avatar
'71 Pinto
2112672924, used $162.80 https://www.ebay.com/itm/03-09-Merce....c100011.m1850
File Type: pdf
Old Apr 11, 2018 | 12:40 AM
Andre91's Avatar
2012 E350 4Matic
Have you checked the brake switch yet? It's much cheaper and easier to replace than the shifter assembly, and more likely to go bad (true on all cars) since it's subject to more wear.
Old Apr 11, 2018 | 05:23 AM
scott099's Avatar
E500
can the used one be programmed with star?
Old Apr 11, 2018 | 11:09 AM
'71 Pinto
Simply need to read/clear fault memory and perform function test with STAR, see line 19 of attachment.
Old Apr 11, 2018 | 11:29 AM
scott099's Avatar
E500
yes I tried a brand new one, no luck
Old Apr 13, 2018 | 07:01 PM
scott099's Avatar
E500
well it turns out someone had HACKED the shifter to even work at all! note the drywall screw holding in the emergency release button, unreal!
the shifter that was on the car wasn't even the same part number, had a different connector... amazing what people will do to save a buck!
got it fixed and I must say it was really easy! shifts again no problem!
looks like all I have it a brake wear indicator left to tackle. ABS & ESP are still off for some reason, but overall I'm happy! thanks again for the help everyone
Old Apr 14, 2018 | 08:32 AM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, A238 E400 Cabriolet 4-Matic
Wow, what a drywall screw hack.
I wonder if a diagnostic code reader such as the iCarsoft MB II would allow a used replacement shifter to work without needing STAR? It does clear the codes. Probably doesn't "run diagnostics" though.
I was very close to having to replace my shifter assembly recently, but tore it apart and found a cracked solder joint on one of the solid state LED light gate sensors on the PC board inside.
