Battery/Alternator Stop Vehicle-Changed Voltage regulator+battery, still not charging
Ordered the voltage regulator from AutohausAZ and had it Friday morning and installed it this evening. It started but the errors were not going away. Swapped batteries with my other Mercedes wagon and drove it around the block a few times. At the end since the warning was not going away I called up the voltage in the gauge cluster and saw that it was gradually decreasing and never was above 12v.
What are other causes for not charging?
Thanks in advance, this will be my weekend until it is fixed
wait for it
controls the batteries. It'd be worth getting a proper diagnosis prior to throwing that spendy part at they car though.
Do you know how to test the BCM? I have DAS and am pretty comfortable with it; but the W211 is new to me. Thanks for your quick post!
This is with the engine running (discharging at 44.5 amps) :
Interior CAN check shows it communicating with the BCM also:
Unfortunately another system seems to have a connectivity issue with the coolant and washer fluid reservoirs:
Tomorrow I will try to check the voltage at the alternator and plan to remove it to take to an alternator shop to rebuild if it is not outputting appropriate voltage.
Thank you again for that ( WIS? ) document, that was extremely helpful.
The alternator was tested as only producing 11.4 volts at pep boys, which is likely the reason for our problems!
I will find an alternator shop to rebuild it hopefully tomorrow - does anyone have a referral in Orange County, CA?
Thanks again for the help so far!
Looking back, I wish that I did that in a more serious way - I only scraped at the bit of oxidation I found there since it was pretty thin; but in retrospect, I should have given it a good scrub with a wire brush. They did test it at Pep-Boys though and I *imagine* they got a good contact with it with their leads.. but who knows for sure.
Thanks for the input, I will keep that in mind when the next alternator issue comes up. With the W202 at well over 250,000 miles and the W210 over 210,000 miles, this will likely come up again, so I appreciate your input!
Have a nice weekend.
