E-Class (W211) 2003-2009
2005 4matic rear differential noise
Old Jul 9, 2018 | 07:40 PM
bruce24's Avatar
2003 E500
I bought another E500 4matic for my wife but rear diff started making noise. I know you can buy bearing set and do it your self but I found a rear diff from a 2006 E350 4matic with low miles wondering if it will fit on E500?
Old Jul 10, 2018 | 04:36 AM
cm60k's Avatar
as i know, 06 "E350 4-Matic" using "3.27" diff. Ratio, while your 03 "E500" comes with "2.82" diff. Ratio,,
don't think it will work, unless if you reprogram you TCU, for Ratio adaptation..!,,
prefer to get "2.82" Ratio, for direct replacement, this Ratio can be found on "E270CDI/E500".
-;ZAYED;-
Old Jul 10, 2018 | 12:53 PM
bruce24's Avatar
2003 E500
And it's 2005 e500 4matic not 2003 not sure if ratio is different
Old Jul 10, 2018 | 02:19 PM
konigstiger's Avatar
'71 Pinto
Old Jul 10, 2018 | 03:04 PM
cm60k's Avatar
Ah, sorry, i thought you talking about your 03 E500..!,,
05 "E500 4-matic" diff. Ratio should be "3.07", this won't work either with 06 "E350 4-Matic", cause it uses "3.27" diff. Ratio..
-;ZAYED;-
