E-Class (W211) 2003-2009
Need this part number, searched everywhere!
Old Aug 8, 2018 | 04:22 PM
Marsaydeez's Avatar
2008 E350
Plastic bracket connecting overflow reservoir hose to fan shroud.
Old Aug 8, 2018 | 07:03 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
https://www.ilcats.ru/mercedes/?vin=...ch&language=en
Did you try Russian EPC?
In US some parts are not available. I just run into the issue with oil filter housing gasket, when it is only available with $200 assemble.
Found the part number and seller in China, but my Mandarin is non-existent.
Good luck to you.
Old Aug 8, 2018 | 07:20 PM
Marsaydeez's Avatar
2008 E350
thanks for the help, I checked the Russian but it's the same diagram.
Old Aug 8, 2018 | 08:01 PM
kajtek1's Avatar
Than Junk Yard.
Old Aug 14, 2018 | 10:07 AM
Marsaydeez's Avatar
2008 E350
Could someone go pop their hood and check this part for a part number?? It's on the right side attached to coolant overflow hose
Old Aug 14, 2018 | 03:26 PM
cm60k's Avatar
Not that sure, but i think this clip not comes separately, it's part of fan shroud assembly..!
-;ZAYED;-
Old Aug 14, 2018 | 03:42 PM
cm60k's Avatar
Ahhh, sorry, i think i catch it,,
it's breather line fitting clip # "211 504 05 40"..
-;ZAYED;-
Old Aug 14, 2018 | 05:17 PM
Marsaydeez's Avatar
2008 E350
Thanks so much cm60k you're the best!!
