E-Class (W211) 2003-2009
E55 AMG acceleration problem after headers.
Old Sep 6, 2018 | 10:20 AM
Vee1990's Avatar
2006 E55 AMG
Im not sure if this is the right place to post this but here goes, I have an 06 E55 amg, i recently installed some short Kleemann headers on it, the car has no mufflers and resonator, before the headers i ran the car with the same setup and it ran strong.
The same setup being, muffler delete, cat delete and resonator delete stock headers. After i installed the headers ive been experiencing a whole slew of problems, first gear is responsive after that the car has almost no acceleration even if i put my foot all the way down to the floor
it accelerates at the same pace. There is a fluttering/ticking sound when i accelerate coming from the bottom of the car and ive been assured there is no exhaust leak, there is also a vibration at the bottom at low rpm's when accelerating aggressively. When the shop installed the
headers they also installed a pair of hi flow cats and new spark-plugs, the cats where installed without my knowing, could they be the issue ? Ive reset the ECU both with the sneaky ECU reset and disconnecting the battery overnight. Please help, thank you guys in advance, cheers!
Header Link: https://ebay.to/2Qac9So
Old Sep 6, 2018 | 11:55 AM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Do you have a CEL? Do you have a tune on the car for the new setup?
You'd be better off posting in the W211 AMG section.
Old Sep 6, 2018 | 12:26 PM
LexBrett2's Avatar
2007 Mercedes E550
You need the ECU tuned.
The new airflow is causing havoc on your MAF calculation of optimal Air-Fuel ratio.
Old Sep 6, 2018 | 12:27 PM
Vee1990's Avatar
2006 E55 AMG
Do you mean check engine light? If so than no its not on, and no i dont have it tuned, should it be?
Old Sep 6, 2018 | 12:57 PM
Strigoi's Avatar
Yes, check engine light.
You need a tune. You can't just go slapping mods like that on without one. For a tune check out Eurocharged. https://www.eurocharged.com/products/c-75-/mercedes-benz/e-class/e55-en/55-series-performance-engine-software
Have you done cooling mods to the car yet? It's a very good idea to take care of that stuff before trying to get more power out of it.
Old Sep 6, 2018 | 01:28 PM
Vee1990's Avatar
2006 E55 AMG
Alright thank you, can they tune the stock ECU or do i need to buy and aftermarket one? Im sorry im not very knowledgeable on this type of stuff.
Old Sep 6, 2018 | 01:40 PM
Strigoi's Avatar
It's done to your stock ECU. You can flash it yourself, send it into them or take your car to them if you're near one of their locations (you should put your location in your profile). When you buy it just let them know your mods/fuel and Jerry will get you set up.
If it's your only car you'll want to flash it yourself. They just email you the tune file. Check their site, they explain all this stuff.
I've done tunes and back to stock multiple times on my E63 and it seriously takes less than 5 minutes to do. Mine is a bit different since I have an E63 and use their OBDII handheld unit for flashing though.
Old Sep 6, 2018 | 01:41 PM
LexBrett2's Avatar
2007 Mercedes E550
Talk to Jerry at Eurocharged.com, he will explain what you need
Old Sep 6, 2018 | 01:42 PM
Bahnstormer's Avatar
2010 E63 AMG, 2003 E500
They can email you the tune after you send them your stock ECU file, which you'll download with one of their devices.
Old Sep 6, 2018 | 01:47 PM
Vee1990's Avatar
2006 E55 AMG
Strigoi I really appreciate the information, im going to look into it! Thank you!
Old Sep 6, 2018 | 02:06 PM
LexBrett2's Avatar
2007 Mercedes E550
ON A CAR LIKE THAT YOU MAY ALSO PICK UP 15% TO 20% INCREASE IN HORSEPOWER WITH THE TUNE
WITH A 500 HP CAR, THAT IS GOING TO BE FUN
Old Sep 6, 2018 | 02:23 PM
Vee1990's Avatar
2006 E55 AMG
Really? Thats good to hear, but there might be cooling issues, no?
Old Sep 6, 2018 | 02:35 PM
LexBrett2's Avatar
2007 Mercedes E550
Tunes are regularly done on modified engines, and actually is completely necessary or the car will run bad.
Just give Jerry a call, and explain your mods and what is happening.
He'll explain everything.
http://www.eurocharged.com/
