E-Class (W211) 2003-2009
2005 e55 AMG Suspension Problems
Old Oct 22, 2018 | 12:20 AM
e55amgflal's Avatar
2005 E55 AMG
Hi MB family, I have been a lurker for a while now I do admit but I finally (sadly) have a necessity to post. I have recently become the owner of a 2005 e55 amg and she is beautiful, however, I am finding myself in a bit of a pickle with my new purchase regarding the airmatic suspension. Let me start off by saying that the car has one year old Arnott rear air springs, and one year old Arnott front air struts. It also has a new air compressor and air compressor relay. I am having an intermittent problem with the suspension. So far I have out about 2,000 miles on the car and I am just recently seeing the problem. On my way back from a trip I received the “Stop car too low” light on my dash and realized that my rear passenger tire was tucked all the way into the fender. After stopping I decided to drive it the rest of the 20 miles home. I took it straight to the shop where they let it sit for a day and without running star on it or inspected it told me I needed to replace everything on my airmatic system... $6000. It goes without saying I drove it home from there after paying them their diagnostic fee. After driving it home I messed with the compressor a little, wiggles it around, found a hole in the intake hose (black) and replaced it and all of a sudden the car worked perfectly for about a week or two. All of a sudden my car is back to leaking as of yesterday because whenever I got my two passengers and I into the car then it says “stop car too low” but with just me in the car it doesn’t trigger a warning. Whenever I turn the car on the compressor kicks on for about 10-15 seconds and then cuts off without the car raising at all. Immediately upon cutting off I get a visit workshop error message for the airmatic system. From there on pressing the raise car button does nothing and neither does any of the suspension settings. I am going to take it to a new shop this week who I have confirmed can pull fault codes from Mercedes but before/while I do so could anyone chime in on what could be going on with my system? It is only an intermittent problem so I was considering valve block but I just do not know. Another theory of mine was maybe the passenger rear was leaking intermittently and then the rest adjusts to it and then the car will not raise it for some reason. Sometime it holds all four heights perfect for 72 hours at a time I know for a fact and then sometimes like lastnight it leaked out to being slammed within 12 hours. ANY help, information, tips, etc would be extremely helpful as I am very new to this. I know that I could switch to Coilovers but if it is something that is going to be less than $1000 to fix then I would like to keep the air suspension as I have all new struts and new compressor. TIA.
Old Oct 22, 2018 | 12:25 AM
e55amgflal's Avatar
2005 E55 AMG
This is on my way home from trip when I first got the error.
At the shop rear after sitting over night
At the shop front after sitting overnight
Old Oct 22, 2018 | 09:16 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Most likely a bad connection or a faulty valve block. PM me your email address and I'll send you some info that will help you to troubleshoot it. Start with soapy water on every connection while the system has pressure. If you have access to STAR (if you don't have one, get one!) you can literally verify each part of the system individually.
Old Oct 22, 2018 | 10:37 PM
e55amgflal's Avatar
2005 E55 AMG
pm sent
Old Nov 5, 2018 | 06:54 PM
No1know's Avatar
E55 AMG, CLK 113K Swap. 2005 SL600
Hi bbirdwell,
I have the same issue can you give some pointers? I do have access to star.
My email is dj_misha@aol.com. Thanks for your help.
Old Nov 5, 2018 | 09:08 PM
e55amgflal's Avatar
2005 E55 AMG
Originally Posted by No1know
Hi bbirdwell,
the thing he sent me was merely a diagnostic page that did not help. If you have access to star this is a huge help. I took it to the shop and after $700 they still don’t know what it was. Replaced the valve block and it did not help. PLEASE let me know if you figure out what this is. Thankyou very much.
Old Nov 5, 2018 | 10:48 PM
No1know's Avatar
can you email that to me, dj_misha@aol.com.
Old May 26, 2022 | 11:48 PM
Z55AMG's Avatar
2005 Mercedes-Benz E55 AMG
did u ever end up fixing it?
Old May 26, 2022 | 11:51 PM
e55amgflal's Avatar
2005 E55 AMG
although I don’t have the car anymore I did end up fixing it. I had a leaking valve block which caused the compressor to burn up from constantly running. Replaced the valve block and compressor and was good as new. Hope this helps.
