E-Class (W211) 2003-2009
Shaking Vibrating @ Stop W211
Old Dec 16, 2018 | 12:56 PM
Dtone99's Avatar
2006 E350 4Matic
I am having a similar issue.
My 2006 E350 is shaking/vibrating when idle. This happens mainly at stop signs or traffic lights. This started about a week after I got a tune up and replaced engine and tranny mounts, which included replacing the spark plugs. I looked up some similar complaints and people were saying the sparks could be bad, but my mechanic assured me that if there was a misfire, there would be a check engine light. I have no check engine light.
The shaking vibration happens when:
Car stops and is in ‘Drive’
The vibration stops when (while car is at rest):
Car is in park, neutral (Haven’t tested reverse)
I release the brake slightly or very gently press the gas. (Barely enough to move the car)
I turn the steering wheel. Sometimes I turn the steering wheel and the vibration stops.
Just need some troubleshooting tips. Cheapest to most expensive. I don't want to spend money at the mechanic fixing a bunch of things that aren't the cause.
Old Dec 16, 2018 | 03:33 PM
mtrevelino's Avatar
2006 E320 CDI
As I said on the other web site:
If they are NOT oem motor mounts, that is where the vibration is coming from.
Mike T.
Old Dec 16, 2018 | 08:39 PM
Dtone99's Avatar
2006 E350 4Matic
When it comes to components located in the engine or transmission, I don't buy after market parts. Since the mounts seem to be the prevailing recommendation, maybe I need to get them re-checked...
Old Dec 17, 2018 | 05:56 PM
blackbenzz's Avatar
haters crazy
Sounds like engine mounts
Old Dec 17, 2018 | 07:09 PM
Edwin 550's Avatar
2008 E550 4Matic
If I switch the mode to S, it will vibrate on gear”D” when stop; switching back to C, no vibration.
I think Engine/transmission mounts are old but not totally worn yet.
Old Dec 17, 2018 | 09:28 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Look at them and see if you have any orange staining in the area. If you do, you need new mounts.
Old Dec 18, 2018 | 01:16 AM
Edwin 550's Avatar
2008 E550 4Matic
I don’t think I saw any orange staining on or around mounts, did I miss something? Or they have been changed by pre-owner?
Old Dec 18, 2018 | 01:53 AM
Strigoi's Avatar
When they go bad the fluid that's in them generally leaks out. It's orange.
Engine mounts are a maintenance item. Do you have any record of them being replaced?
Old Dec 18, 2018 | 03:08 AM
Edwin 550's Avatar
2008 E550 4Matic
Got it, I thought it was kind of marker by factory workers. I don’t have any information from the pre-owner, a divorced lady, she knew nothing about the car of her pre-husband. Sad story......
