Best way to troubleshoot air spring?
Upon starting the car, the bag lifted the car back up a bit, but not all the way, and the right corner is noticeably higher.
After letting the car run for a few minutes, I killed the engine and went back inside to do some research. One site I came across indicated that when parking on an incline (as I do on my driveway) sometimes the sensor can make mistakes and end up dropping or raising one side too high. Taking that with a grain of salt, I took the car for a short trip to the gas station and back for fuel. Upon returning, the driver side is still lower than the passenger, but now that I am leaving it on level ground, the car seems to be holding the height.
I'm fairly convinced this is probably a leaking rear airspring. What is the best way to confirm? I have an icarsoft MBII to pull values if it is relevant. As a side note, what is the expected lifetime of an OEM airspring? when I bought this wagon, I thought I would be dodging that bullet because the airsprings had previously been replaced under warranty. With the miles I have on it now though, I'm wondering if I just ran them through their useful lifetime.
https://www.rockauto.com/en/catalog/...r+spring,15005
I'm not getting a warning from the dash about the car being too low, and when I start the car and drive it, the driver's side seems to come back to at least a nominally normal height. Is it safe to drive in this condition?
Arnott's site says that if replacing OEM air springs, they should be replaced in pairs. Is that an imperative instruction, or can they be replaced one at a time at my leisure?
As for installation, it's a simple job.
Other things to check are to see if valve block is leaking or the rear junction.
In the rear, a single line comes from the valve block into a splitter, check for leaks.
