No start after transmission replacement
After transmission replacement car will not start
Starter engages and cranks fine, fuel pressure is fine. It acts like a bad CPS i installed a new bosch unit, tested wiring back to ECU al is fine but still wil not start. Injectors are not firing and theres no spark.
Went thru all the fuses lookong for a problem there nothing.
What am i mising ? What part of installing a replacement transmission could cause the engine management system to fail ?
It dose continue to have the p0335 code i can clear it but it comes right back after cranking.
I went back and rechecked the new CPS , connector and wires to the ECU and see no problems.
Any thoughts on what could be causing this no start would be greatly appreciated
Thanks Steve
The usual method is to use the TCM from the original transmission. The shop that did the transmission swap should be consulted to be certain that they did this. If they did, the problem is likely to be elsewhere.
There may be a way to re-program the system, but it is well beyond my level of expertise.
Do you have any codes?
