CDI - Winter Problems??
I live in Michigan, where temperatures of -5C are common and -20C is not unknown. Am I in for trouble with fuel gelling and freezing of fuel lines due to water in the fuel? Are there work-arounds? Do you use fuel additives in cold weather?
I'll greatly appreciate your experience with CDIs in wintry weather. Many thanks.
-Karl
E320 CDI scheduled for ED on 9/29/04 (I hope!)
[B]Hi all. The CDI has just come to the USA, so has no track record here as yet. I have an E320 CDI on order, and am a little concerned about its behavior in the winter months.
I have a new cdi too, but I also had an older diesel, and I've never had any problems in cold weather evern though I don't get too many cold days below 0 F, that car had a block heater, I don't even know if my new cdi has one. The fuel sold is usually winterized and you can always add a little kerosene, even tho MB says not to.
Northern states generally sell a blend of #1 and #2 diesel fuel in the winter.
The CDI should have a block heater or one should be offered.
With blended diesel and a block heater, we drove our 1984 190D in -40F Minnesota temps. The fuel didn't gel.
There is one advantage with a diesel that's not possible with a gasoline engine. You can let them run all night w/o harming them.
You shouldn't have any problems but I'd ask your dealer if the car has a block heater or if you can have one installed.
