Transmission jerks when I put in D or R
1 Post
ml/e420/others
lol good luck with the "solenoid"
"tuff guy behind a computer cursing" lol i can see you are just a little kid that needs alot of growing up to do.
anyways when Mercedes have these problems 90% of the time its better and cheaper to change the transmission. BMW has the same problem also.
The following 2 users liked this post by benznyc:
gagan takker (11-21-2021),
hashim1995 (04-28-2022)
We’re you able to resolve the issue? Mine is doing something similar, but when I disconnected the wires to the shifter and reconnected them the car disengaged limp mode... for a while.
M-350 (07-17-2019)
I Am dealing with the same issue. During my research I read about the fact that there is two batteries in the Mercedes and the second auxiliary battery if it has low voltage can cause that problem.. didn't see anybody else mentioning it thought I would give you a heads up. Also if it is plate or speed sensor it's code p0715.. I replaced the entire plate and the speed sensor and 13 pun connector with a lot off of Amazon for $68. You don't need to take it to a dealership and you don't need to have them order a special place that nobody else can get. Check your auxiliary battery and your main battery. If you don't have a scanner that can clear the codes out of the TCM no matter how many times you fix it it's not going to go at a limp mode and you're definitely in limp mode.
P0715 Transmission input/Turbine Speed Sensor
