E-Class (W211) 2003-2009
Fault code help
Old May 27, 2019 | 11:12 AM
terrysmr2's Avatar
Mercedes E240 2003
Fault code help
Hi all ran diagnostics on my 2003 E240 w211 this afternoon to check on the brake warnings on the dash and I got the code C228F A7/3n1 SBC control unit internal fault. is this fault that can be cleared without replacing any parts or will I have to order up a new sbc control unit and replace it, also is it a unplug and replace or will the new one need to be programmed to suit the car ? Many thanks in advance for any help or advice
Old May 27, 2019 | 11:29 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
If you are in the United States, it is covered under the 25-year unlimited-mileage warranty.
If not in the United States, you are going to have to purchase a rebuilt version (multiple part numbers for the unit as it was upgraded over the years; search this forum under the user name Konigstiger). No programming needed but STAR will be needed to properly bleed the system.
Old May 27, 2019 | 12:22 PM
terrysmr2's Avatar
Mercedes E240 2003
Sadly I'm in the UK where MB seem to not want to cover the cost of a replacement under warranty. Oddly my diagnostics show that the pump is running fine and the pressure within the system is ok and holding fine I take it the electronic side of this unit can be swapped out separate or is it a complete unit
Old May 31, 2019 | 03:31 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Pretty much a complete unit. The pressure reservoir is about the only piece that can be replaced separately.
Old Apr 1, 2020 | 01:59 PM
miniion26's Avatar
2005 W211 320 CDI
Hello, OP
Any updates on this, how did it get solved?
