Front Suspension Clunking noise going over bumps.
I have been chasing this front suspsion noise for the time that I have owned the car. The noise usually happens when going over medium sized bumps and sometimes small ones. The noise is a clunking noise and almost sounds like a component is loose. So far I have replaced Lower ball joints, Upper control arms, and just recently sway bar links. Any help would be greatly apreciated because this noise is driving me crazy Thanks, Chris.
2009 Mercedes E350 4Matic
just slowly creep forward and dap the breaks then reverse and press the brakes. Then repeat by going forward and dab the breaks and you should hear that clunking noise if this is the issues.
Hope this helps
2009 e350 4matic
Hope this helps
rgrds Gaz
