E-Class (W211) 2003-2009
HK Audio Gateway retrofit question (plus Qs about handsfree/BT)
Old Oct 24, 2019 | 05:52 PM
Broly's Avatar
2002 Acura TL-S and 2005 E320 4MATIC
Hello everyone,
First of all I want to commend you on your DIYs and all of the information on this fantastic generation of Mercedes vehicle.
I have a question that I feel previous posters haven't really asked.
Is it possible to retrofit the HK Audio Gatway into non-HK vehicles?
I have an 05 E320 4MATIC that seems to have the logic7 system (i haven't checked for the sub yet), and I do not have the 'sound' softkey on my COMAND.
Is it possible to simply drop in an HK AGW and have this option? Or must I add the missing speakers. Only the sub is missing, though, right?
Additionally, I want to add bluetooth handsfree to the vehicle, I am curious if I have all of the parts necessary to install in the carrier plate:
A2208271842 - radio booster
A2118204385 - UHI module
A2115456740 - linear compensator bracket+module (bt module i assume)
A2115406433 - MOST cable without Voice control (i understand it does not work with NAV)
A2038201311 - surface mount
does this cover everything? the most cable without voice is already in the carrier plate, right? or do i have to buy it?
same goes for retrofitting an HK amp: does it need a different MOST cable? I hope not!
thanks for your help.
Old Oct 25, 2019 | 12:15 PM
rocky472's Avatar
Two 2005 E320 CDI, 2004 E500 Wagon, 2007 ML63 4MATIC
I added the bluetooth phone the my 05 e320CDI. Attached is a MB installation procedure I found on one of the forums. Your vehicle should be prewired. Installation of the antenna components is not needed as modern phones will not use them. The hands free worked without coding and displays in the head unit. Audio quality is very clear. Note that the bluetooth only works for calls, not audio streaming. As noted in the installation procedure, you need to update the vehicle settings to have call information show in the cluster. I also installed the linguistic module but it did not work. The fiber optic connections are fairly easy to install and modify. I needed to purchase a small extension from eBay. Make sure you have the fiber in/out connections correct or the system will not function. With the exception of the cradle, I purchased everything on eBay. The false door shown in the document is no longer available. My 320 has the logic 7 system so not sure about the retrofit. I do know that if you have it, there should be more speakers in the vehicle. Good luck with your install.
File Type: pdf
Old Oct 25, 2019 | 01:44 PM
Broly's Avatar
Hi Rocky,
what do you mean the antenna components are not needed? are you saying the linear compensator and/or the antenna splitter(s) are not required?
I do have the walkthrough for installing all the components, i just figured the antenna splitter/compenstator were required.
surely i still need the splitters? just not the linear compensator?
thanks
Old Oct 25, 2019 | 02:23 PM
rocky472's Avatar
The antenna feeds the cradle interface in the console. If you are using a modern cell phone there will be no way to connect to it without an adapter. I left the current connection to the tele-aid module and didn't add any of the additional splitter/antenna amplifier components. The Bluetooth puck does not use the antenna feed. You need to install the MHI module shown in Fig 5 of the document. That's what talks to the Bluetooth puck
Old Oct 28, 2019 | 03:09 PM
tartilc's Avatar
2005 E320CDI
Hi, I actually retrofitted the full HK system into my 2005 E320 CDI. First off, you can just swap the audio gateway and it actually all works even if you change nothing else. I did that first just to see what happens and I didn't notice much of a difference in sound quality though (maybe a bit worse actually). In order to do the full conversion you need the rear deck unit (subwoofer + two more speakers on each side), the antenna with I think its like a dynamic range microphone mounted on the rear driver side pillar, and all the speakers (center dash, one midbass and one tweeter in each door, and two kickpanel speakers under by front dash/floor). The rear deck unit and dynamic range unit are the only things that have extra wiring, one plug for the subwoofer wiring, one for the dynamic range unit (these two plugs do not have a spot on the non-HK gateway to plug into), and the two speakers on either side of the subwoofer have I think four wires that need to be put into empty slots on the stock non-HK gatway main speaker harness plug. The HK speakers are actually a lot beefier looking (way bigger magnets) than the non-HK ones. No wiring has to be run from the doors, front, etc, everything is done by disassembling the trunk paneling and rear parcel shelf. Immediately upon installing the gateway you get the sound option on the COMAND unit.
As far as bluetooth I don't know if the MB bluetooth puck is a great idea as they're pretty old now. Maybe look into getting one of those LaPower units people were talking about on the forum, I was thinking of getting one myself.
Old Nov 16, 2019 | 02:35 PM
Broly's Avatar
hi,
just curious: does anyone know if the rear shelf wiring harness is present on non HK vehicles?
same goes for the wiring of the antenna amplifier in the rear driver side pillar.
edit: another question i have is if i need to upgrade the fuse after adding the subwoofer/rear shelf. not sure if the added draw of the HK speakers plus sub would trip the current fuse.
Old Nov 17, 2019 | 04:01 PM
tartilc's Avatar
2005 E320CDI
Neither the subwoofer unit nor dynamic range microphone wiring harnesses were present on the non-HK cars. The harness clips into the plastic housing of the subwoofer and then runs down to the top driver side back seat bolster area and then into the trunk all the way to the gateway unit. I do not think the fuse needs to be upgraded.
Old Nov 17, 2019 | 04:50 PM
Broly's Avatar
thanks buddy. yes i will tell the person who i am speaking with about these parts to take extra care. it is good to know this wire harness is connected to the amplifier as well. i hope i can connect it from the rear shelf instead of having to undo the SAM+NAV again.
i think it will be a long while before canadian junk yards get W211s. i did see one in calgary as i perused the go-to websites, but i bet it has already been picked down.
not as many of these cars up here as there are down there.
just to give you guys an idea of how far MB goes before salvaging cars: the Biggest Lemon Of Them All (1st gen ML320) is still on the road up here.
we had one brand new and it is the most unreliable car we have ever owned.
my mother doesn't even dignify it by calling it a mercedes or ML. she simply calls it "the lemon" and we all know which car she is referring to.
it was terrible. yet people are still somehow driving them up here. imagine how much money has been spent to keep that trash on the road...
Last edited by Broly; Nov 17, 2019 at 04:55 PM. Reason: just explaining to my american friends how different the attitude is re: salvaging MBs
Old Nov 22, 2019 | 09:02 PM
Broly's Avatar
finished up the speaker retrofit and just being patient in terms of the gameplan for the rear shelf + wire harness + antenna amplifier.
i wish tarts had his PMS enabled, we had a great exchange. i bet he got in trouble by someone for giving me TMI but either way thanks tarts i think the hardest part is done.
though i've heard others say getting the rear shelf out is a pain because of the clips underneath the headrest opening. we shall see (soon, hopefully)
Old Nov 23, 2019 | 01:57 PM
tartilc's Avatar
2005 E320CDI
Interesting I had no idea PM's had a limit on them but it seems I've hit it, gonna clear the messages out. Awesome to hear though, you're almost done. The little headrest tabs are ridiculously annoying to deal with, a small pick with a bent end on it worked best for me. It still took like at least half an hour of struggling with them to get them all out though. After that the parcel shelf comes out easily enough (be careful with the two side pillar panels as the middle section clip is a bit fragile).
Old Nov 23, 2019 | 02:01 PM
tartilc's Avatar
2005 E320CDI
Hmm, it seems my account has some type of restriction it? Can an admin/moderator take a look please, thanks.
Old Dec 26, 2019 | 06:39 PM
Broly's Avatar
just want to bump this thread.
you do NOT need the antenna amplifiers. i purchased them because tartilc is the only active person to share information about the retrofit.
after hunting for the rear shelf wiring harness and other parts, i realised that both the yellow and black cables going into the amplifier (HK or not) are from these antennas. so don't bother.
what is needed, however, are the wiring harnesses for the rear surround speakers and the subwoofer.
Old Jan 10, 2020 | 10:24 PM
Kelly Martin's Avatar
E320
I have a 2005 E320 with a bad audio gateway. Does anyone know if a used one can be used or are the parts coded? I have the Harmon kardon /Nav unit
Old Jan 11, 2020 | 11:35 AM
Broly's Avatar
yes you can easily put in a new one kelly.
i actually did not have the HK AGW originally and it worked just fine.
should not be a problem
Old Jan 17, 2020 | 10:57 PM
E320
So I can’t find a new one. Can a used one be put in instead?
Old Jan 19, 2020 | 08:57 AM
Broly's Avatar
yes
Old Jan 21, 2020 | 07:58 PM
Broly's Avatar
full retrofit (excluding mic, because i heard it sucks and also when i remove the headliner i may as well ponder PDC...) completed 20/01/2020.
the sub isn't SUPER powerful as some others pointed out, however it is quite cool hearing the surround effect from the rear shelf. i wonder if the rear speakers are turned down deliberately, as the centre speaker (which is the same as the rear speakers in the parcel shelf) is much louder.
lots of surround sound buffs (home audio) always said "it should be as if all the sound is coming from the front", so maybe that's what they were going for here. i know someone sitting in the back would feel the bass and hear enough from both the front and back to enjoy it.
anyways, i was incredibly surprised at how fragile the connectors are for the surround speakers in the shelf. i plugged in the connector and broke it by trying to unplug it. no matter, as i just converted the speakers to quick connects.
very happy i got the wiring done. now if i want to upgrade the rears a little, or play around with the setup, no more fiddling with the ****ing trunk. this amp seems it could power the rear much more than it does.
time to see how uncivilised some people got with their modifications to this amazing sound system, just to guide my future work.
Old Feb 1, 2020 | 11:05 PM
E320
Thanks Brody!
Old Feb 1, 2020 | 11:06 PM
E320
Red face
Broly. Damn spell check
Old Feb 9, 2020 | 10:45 PM
E320
So the MB service center installed a rebuilt audio gateway and I was good for about a week. Radio and command center worked fine then last night alarm was going off and battery was dead again. Anyone else been through this? 05 E 320 with battery drain supposedly due to audio gateway issue.
