E-Class (W211) 2003-2009
OK to mix MB ATF 134 & Pentosin ATF 134?
Old Nov 12, 2019 | 11:39 AM
Irastock2's Avatar
1983 300D; 2016 E350 Wagon
I have a 2005 E320 CDI. It currently has MB ATF 134 transmission fluid in it. I am going to change the transmission filter. Is it okay to replace fluid with Pentosin ATF 134 (cheaper) so that the 2 fluids mix?
Old Nov 12, 2019 | 12:32 PM
tjts1's Avatar
C320
Sure why not.
Old Nov 12, 2019 | 11:23 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Manufacturers always recommend against mixing the same fluids of different brands, what applies also to motor oils, yet owners do it and reports about something going wrong are not coming.
Still it should be concern as it would take chemist to compare chemistry of 2 fluids.
With pan drop you need 4l of ATF. How much money you save? Will it cover potential tow truck fee and repairs?
But regardless, feel free to become Guinea Pig for the rest of us.
Old Nov 12, 2019 | 11:35 PM
cetialpha5's Avatar
I'm not sure what manufacturers you're talking about. Even Mobil says it's ok to mix different brands of oil, you just don't get the same "superior" protection that you would get with theirs.
Really, this whole question seems to bypass the entire concept of a spec. If the fluid meets spec, you can mix it with another brand that meets the same spec.
This actually happens all the time. People take their cars to various garages and the garage doing the fluid change really has no idea what the previous fluid in there was. They just use a fluid that meets spec and the car continues on as before.
http://www.mobil1.com.hk/academy/faq.aspx
Old Nov 13, 2019 | 12:35 AM
kajtek1's Avatar
Do you mix Scotch with Bourbon? They both have the same classification
Old Nov 13, 2019 | 12:59 AM
cetialpha5's Avatar
They don't have the same milspec requirements that the military has regarding fluids. If there's a specific spec that is called for in a particular application, it shouldn't matter who makes the fluid. It's why you don't all your eggs in one basket, multiple suppliers in case one has a problem.
And to answer your question, while the taste may differ, they're both alcohols and the mix will get you drunk.
Old Nov 13, 2019 | 01:16 AM
kajtek1's Avatar
Or sick.
If you don't do it to yourself, why do it to your lovely Mercedes?
Old Nov 13, 2019 | 01:58 PM
EuroDriverSD's Avatar
2016 E350 Sport; Mom Wrecked the 2008 E350; sold the 2002 C320
IMHO, it's the same oil, different container and label. Some claim to add more detergents or stabilizers but they all must conform to the same specifications to get approved.
Practically all of the parts on our cars are made by a manufacturer other than Mercedes Benz and sold to Mercedes as well as many other suppliers. Each puts its own brand label on them.
Old Nov 14, 2019 | 02:26 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
I've mixed OE 134, Shell 134 and Pentosin 134 many many times. No problem. Use BEVO and MB can sometimes lists numerous brands as equivalents. Nowhere does it say you can't interchange them over the service life of the vehicle.
Old Nov 14, 2019 | 04:02 PM
kajtek1's Avatar
Did you ever bother to look for any info on the subject?
When I don't have maintenance manual who would give details on ATF, My owner manual clearly says
"Using engine oils of another quality is not permitted and may invalidate the New Vehicle Limited Warranty"
I bet you will find similiar notes on ATF use and guess who will have last word what "different quality" means?
Old Nov 14, 2019 | 04:57 PM
cetialpha5's Avatar
I know English is your second language, all the fluids listed in MB approved sheet are of the same quality. That's what they mean by another quality.
The military uses the same fluids for their vehicles and they require that any fluid that meets spec should be interchangeable with any other manufacturer's fluid that meets spec. That's really the whole point of a spec. You're making a mountain of what is basically a molehill.
Old Nov 14, 2019 | 06:08 PM
kajtek1's Avatar
Make it 3rd language
This is your interpretation of "different quality".
Just like sample with Scotch and Bourbon, the same specs can be delivered with different ingredients and you have no way of knowing if some of those ingredients will not interact with each other. Why don't you mix 2 different whiskeys?
If you read diesel section, you will find several reports about relatively new engines seizing becouse dealers put in them "same quality" oils by their own specifications.
I am not saying each such mix has to end in disaster, but who gives warranty it won't?
Again, feel free to try and report back after some time.
Old Apr 17, 2022 | 12:33 PM
viermatic's Avatar
e320 wagon 4m
mixing transmission oils
different fluids may mix at certain temperatures and pressures and yet may fall out of solution with each other under different temperatures and pressures. So you may get unexpected changes in performance on especially cold or hot days, or under higher levels of performance. The chemistry is not trivial. If you want to avoid surprises, it is best to use the same oil and stick to that one oil. To flush out a transmission system, I have read it takes 3 flushes. At the end of the day, sticking with the manufacturers suggested oils is your best course.
But if it were me, so long as the oil you are using is on the specific approved oils list for your specific VIN #, I would have no problem adding the pentosin atf 134 to the existing MB oil.
