E-Class (W211) 2003-2009
E55 Audio not working HELP!!!!
Old Nov 15, 2019 | 09:37 PM
germangearhead's Avatar
2004 E55 AMG
Angry E55 Audio not working HELP!!!!
Hi folks! havent posted here in a long time, my e55 is having some issues that I just cant figure out.
last year I blew my radiator, snapped my steering rack and had 2 bad wheel bearings and at the time just didnt have time nor could afford to fix it so I parked it for the better part of the year.
when I finally got around to fixing it everything was going fine. Replaced the wheel bearings, took it out for a drive and all was well. I left for work for 2 weeks; when I got back I went to go do the Steering rack...this is where all the problems started. When it was on the lift I noticed the rear right tail light was flickering, headlights werent working, some interior lights didnt work and Radio wouldnt turn on. After scanning the car I came to the conclusion that my REAR SAM took a crap. I swapped out the whole unit with a used one that shared the same partnumber as mine. This fixed everything except my radio.
So as of the last couple weeks I have been trying to track down why my radio will turn on, shows the logo and then shuts off instantly.
things I have tried:
1. replacing all blown fuses (engine bay, drivers side door, and rear sam)
2. MOST fiber loop on cd changer and navigation
Now the only thing I am unsure of is the SAM module, when it is replaced will it cause issues with a radio not working? I dont want to spent the money to have it programmed to my car if its not going to solve anything.
I am very new to all this diagnostic work, I can replace parts and service the car as I have done the last five years but this is all new so any and all help is welcome
Thanks!
Old Nov 16, 2019 | 08:33 AM
konigstiger's Avatar
'71 Pinto
FWIW next step need to have someone check for fault codes and transfer / code data specific to your vehicle before moving to replacing parts.
